Question about Waring WMK300 Professional Belgian Waffle Maker
No heat waring pro wmk300 - Waring WMK300 Professional Belgian Waffle Maker
  • Mark Gidding Apr 27, 2008
    Ours was made in 2004 and worked nicely until it simply stopped heating; power supply is good and power indicator light comes on - the parts check on line states the printed circuit board is no longer available. I hope there is another source for parts.
The problem with these units is a fuse located under one of the stainless grill covers. Mine was under the cover that does not have the handle attached. It is located in a white sleeve by the main hinge. Fuse can be bought on amazon.com. It is thermal fuse 240C. Replacing the fuse is the easy part. Getting the small black screws out so the cover will come off is not. They are held in with thread lock or epoxy, They are easy to mess up, so be careful.
Posted on Jan 25, 2009
The fuse is the answer00.
Posted on Jun 24, 2010
SOURCE: waring pro wmk300
After numerous fixes and replacement units I did finally contact Waring directly through their website.  I explained my situation and reported all the posts I had seen regarding the same problem. They responded quite quickly, sent me a UPS return sticker and within a few weeks sent me a new unit.  I cannot find the manufacturer's date on the unit, but it is different than my previous units.  The bottom stand is now made of plastic.  No worries though, so far so good, waffles for breakfast again.  It's been two months now, I'm keeping my fingers crossed.  Try contacting them directly, I found them better than any store or repair shop.  They have to be aware of this problem and I don't know how a recall happens, but they probally would much rather replace your unit than recall all units.
Posted on Feb 25, 2008
SOURCE: Belgian Waffle Maker Problem
Receipt not needed - 1 year warranty from Waring, they will replace the entire unit.
Posted on Mar 03, 2008
SOURCE: Waring WMK300 professional Belgian waffle maker
Your thermal cut-out went bad, needs to be replaced.
Posted on Mar 18, 2008
Jerseybob
  • 18 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Posted on Apr 02, 2008
SOURCE: I've lost the owner manual/recipe book for my
Here's the link:
http://www.waringproducts.com/ret/share/man/80_man.pdf
Posted on Nov 12, 2011
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Feb 15, 2014 | Waring WMK300 Professional Belgian Waffle...
Unit has power light on but quit cooking waffles - not hot to touch
the heater element is not being powered....solution is to replace the thermal fuse which is in-line with the heater. the unit must be opened up, the fuse is usually hidden inside an high temperature insulating sleeve...cut the old fuse out, replace it with the same temperature rated fuse other wise, it will continue to blow fuses or the heater element may burn out completely....check the old fuse, if it says...90, then it is rated for 90 degrees celcius ,...so on..it must be replaced with the same value...you cannot solder these fuses in...they must be crimped because the heat will melt the solder connection....if you can't do it...get a pro to do it for you
Aug 15, 2009 | Waring WMK300 Professional Belgian Waffle...
Will not heat.
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. This appears to be the weak part of the circuit. A replacement can be found here on Amazon.com.
Aug 10, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Pro WMK300
go to the manufacturers website and contact by phone
Jan 23, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Jan 19, 2008 | Waring WMK300 Professional Belgian Waffle...
Sep 02, 2007 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
830 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
