Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Engine turns once and lawnmower won't start; even
We turn the key, then there's one engine rotation, then nothing
Ook at the contacts on the key swith mabee fryed it with the charger? or the lead to the silinoid could be badd
Posted on Jan 18, 2011
Murray riding lawnmower #309029X92 can't turn shaft, Won't even start,
Karen, try to spin the top of the engine by hand. it should rotate, if it don't check to see if the starter has locked into the flywheel. make sure the blades are disengaged the brake pedal is pushed in and you are sitting on the seat.
May 30, 2016 | Murray Garden
Switch that will not let me start the tractor is not responding. can I wire around it, once I identify it, without causing any other electrical oroblems?
Hi Harold:
Is the MOTOR TURNING OVER and just not starting, or is it not turning over at all? I've unintentionally levelled some rocks with the lawnmower and when it stoppped abruptly, the key in the flywheel had sheared off. The motor WILL NOT START until it is replaced and the flywheel is back in the right alignment.
If your starter does NOT turn the motor over, you will need to track down a different problem. There can be safety switches, lots of them. Make sure the park brake is on, blower is DIS-ENGAGED, and you're sitting on the seat.
Mar 03, 2015 | Garden
Won't start unless check engine light is on
I would suggest having someone check the circuits at the key switch.
The switch could be going bad.
The check engine and other warning lights must come on as a self-test when you turn the key on, then go off once the engine starts.
Jan 16, 2013 | 1995 Honda Passport
1994 Honda Prelude si starting problems
Your starter motor is either not getting power or in need of replacement. Otherwise, there is nothing wrong with your car.
Also check your battery connections for no corrosion there as well as by the starter motor. Low voltage circuits in a car are extremely vulnerable to poor contact issues.
Mar 29, 2017 | Honda Prelude Cars & Trucks
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
Sprayed down lawnmower with water, now it won't start. I decided to "wash" the lawnmower last week and now it won't start. And the really weird part is the solenoid clicks every minute...
Engine will not run with no spark or a weak spark. Continuity test will only reveal that the winding is not open, not if you are producing a weak spark that will not jump the spark plug gap.
Mar 31, 2017 | Garden
Front right side hit . replaced concerter and won't crank over /or start fuel pump doesn'd even come on when key is on ?
ricks63toy, I believe that Ford still uses what is called an inertia switch even in the hybrids. This switch will shut off in the event of an accident shutting off the fuel pump. This is a safety feature built into the vehicle. Seeing that this is a newer vehicle I trust that you still have the manual. If not, the switches are usually located in the trunk. Look on the side walls of the trunk and see if you can locate it. It is usually marked by a sticker. When you find the switch, push the red button down until you hear a click. This will reset the switch and allow power back to your fuel pump. Good luck with this.
May 17, 2011 | 2010 Ford Fusion Hybrid
Intermittent starting when key is turned.
Rick,
there may be a fuel problem. The fuel pump may not be working properly. Also, if the vehicle has been run out of fuel, there may be air in the lines and turning the ignition off and on will turn on and off the fuel pump which could push the air bubble through the system long enough to let the vehicle run and when it is turned off the air bubble will work its way back up to cause problems again. There may be a problem with the wire from the ignition to the fuel pump as well. When it wont start, you can pop the fuel line off the fuel pump while the ignition is on, or have someone turn the engine over while the line is off and it should push fuel out. If it pushes fuel out, you may have an air bubble in the line somewhere. You can get rid of the bubble by turning the engine over and crack each injector line off one at a time while the engine is being turned over.
Hope this helps!
Nov 11, 2008 | 2002 Lincoln Navigator
9-5 will not start
Hi,if the engine won`t turn over may be is stock(demage).Try to turn engine by hand fiting a tool on a cranckshaft polley.If is very hard to turn or don`t at all,the engine must be repaired.
Oct 16, 2008 | 2000 Saab 9-3 Viggen
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
