You need a new hard drive or reformat the one you have with a laptop or PC.
Controll Panel > Administrative Tools > Computer Management > Disk Management (on left)
Hook up the hard drive with an external USB case ($5 on eBay). Right click on left side and initialize.
When that is finished, right click in the middle of that hard disk (where it says --GB unallocated) and click on format. You need to for mat with NTFS first then follow the steps again to format it in FAT. When thats done, re-install the hard drive into the case and reattach to the Xbox and it should be good to go!! Good luck and happy gaming!!!
I must be a frickin genius cuz no one else has found this out yet and im not suprised. this is not a 1 time only thing here, and ull hav 2 do this every time u wanna play, but it works. its
as simple as this: put it in ur freezer. making the hard drive cold
compresses the wires into a smaller path, allowing data to flow faster.
keep the hard drive in the freezer for about 15 minutes to a half an
hour. hope this works
every time i put in an xbox 360 game, it prompts me to the usual update and right after you start...
(More)
every time i put in an xbox 360 game, it prompts me to the usual update and right after you start the update it says "can't download the update". i've cleared the cache thing and even tried it with another xbox but i'm still getting the same problem...
there isno visual on my x box when i plug it in i can hear it but not see it and its not the high...
(More)
there isno visual on my x box when i plug it in i can hear it but not see it and its not the high def. switch
Nascar 09 was working fine but now when I try to run this game it freezes when loading my saved...
(More)
Nascar 09 was working fine but now when I try to run this game it freezes when loading my saved settings. Any help would be appreciated.
will not dispay any video on the tv but green lights are on as usual. is plugged in same as normal....
(More)
will not dispay any video on the tv but green lights are on as usual. is plugged in same as normal. started fading video during game and when restarted will not show anything
