Front loader washing machine will not go through spin cycle. door locked shut. cant get clothes out
    Genius:
  • 1,073 Answers
Most frount loaders have and unlock pull ring on the door latch switch, it will mean removing the bottom access panel to reach up inside the machine and pull the release ring down to unlock the door
Posted on Apr 21, 2008
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Front loader leaking out the front door as is clothing stuck in it, How can we release the door lock. We've stopped the cycle.
Restart the machine...
On a NEW CYCLE... The first thing the machine
should attempt to do... is to drain itself.
If it does not...
UNPLUG IT... Restart it on a spin cycle ... or regular
wash cycle...
Carnac the Magnificent YZQ7YL
Jan 21, 2017 | Washing Machines
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
