Question about Harman Kardon FL8385 5-Disc CD Changer
How do i get cds out of the player. Unit was unplugged and moved and cd's got moved inside
  • 17,130 Answers
You will have to open the set before you switch on. Be very careful not to damage the opticalhead or the delicate mechanism. if the cd is out of the tray use a good light to carefully understand how to track it back to the tray. Use a soft tool to push it back as usually it will go back as it had come back. You can also assist the loading mechanism to be turned at the motor drive to release. repeat the process to retrieve the cd. Do not break the cd's but push the edges by guiding it . I hope you do it right. Good day
Posted on Jul 20, 2010
Cd skips at beginning of cds
the data on compact disks usually starts on the outside of the disks and spirals to the center. My guess is that the laser unit that reads the data is malfunctioning. It moves on a rail from the outside of the disk to the center. About all you can do if try to clean the laser unit or lens assembly. If you can get to the laser lens, blow it off with canned air. If you can not get directly inside, open the CD drawer and shoot the canned air into the machine through the drawer openings. I suggest that you open the CD drawer with the open button then unplug the machine. At that point the drawer should be open and you will have some access to blow off the CD reader.
good luck cleaning the CD reader!
Jan 28, 2010 | Sony CDP-CX300 CD Player
TABLE ERROR SHOWS IN WINDOW
What probably happened is that some CDs fell off their tracks and are blocking the main wheelhouse from turning. To solve this you will need a philips head screw driver. First unplug the machine. You will need to remove the top of the unit (which slides off towards to the back) after removing the 9 screws (2 top, 4 side, and 3 top back). Once you slide off the cover, you will expose the wheelhouse and you should see the CDs that fell off. Simply take the cds out. Once you have taken out all the CD that came off the tracks, slide the cover back on and screw in the 9 screws. The CD player should work again. This worked for me and hopefully will work for anyone encountering this error.
Dec 01, 2009 | Sony CDP-CX300 CD Player
Cd is stuck inside the player. I moved the unit when decorating and now the unit will not play any cds and there is one stuck inside. I removed the casing to look inside but got scared off when I saw all...
It is safe (except for the lead solder) as long as the unit is not powered ON.
There is a "pin hole" on the front of the CD tray.
With power OFF, use a stylus (straightened-out paperclip) to push the mechanical eject button inside the pin hole. Carefully use enough force to push the CD tray out.
Oct 13, 2009 | Audio Players & Recorders
JBL 6 CD AM/FM Cassette Audio has CDs stuck inside and won't play or eject them. How can I get them out?
I've had this happen before with car stereo's uh i just normally unscrew the screws out of the top of the player to where you can get to the tray or slot for the cds and force the cd tray or the cd itself out but be careful and not break the cd this might work it usually does for me
Aug 17, 2009 | JBL MCDC100 6-Disc CD Changer
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Feb 15, 2009 | Audio Players & Recorders
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
I have a Pioneer CD player that is probably about twenty-five years old. It has a six CD holder that fits into the changer. This changer moves the CD's in and out of the player. You can play them in order...
It cycles through the CDs because it can not read any of them. The most common cause of this is the lens falling out. These players have the optics upside down. You load the CDs with the label down correct? The lens is probably floating around inside the unit. Sometimes you can reinstall the lens and the unit is OK. Please use a small amount of clear nail polish to "glue" the lens in place. Anything else will cloud up the lens making the unit junk. If that fails to resolve the problem, the unit may need a ribbon cable or just a complete alignment.
Good luck.
Dan
Nov 28, 2008 | Pioneer Audio Players & Recorders
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
Technics SL-PD9,SL-PD7A
Ouch, you should not have disconnected the front door.
Unplug.
Take the lid off.
take all CD's out.
Figure out where the plastic bit goes.
Good luck.
Sep 23, 2007 | Technics SL-MC6 CD Player
Harman Kardon FL8385 5-Disc CD Changer Logo
130 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
