Question about Viking Kitchen Ranges
30 inch Viking ultraline stove, 6 years old. You have 2? burners on the bottom in the oven. One on the right "buffs" or seems to go out then reignites. The "cook" also says it takes a while to heat up. Any ideas? Thanks Greg
  • johugs Dec 10, 2008
    I bought this stove in Dec 04 and we are so unhappy with a product that we always DREAMED of owning.
    The first year so several repairs to the igniters, under warrenty, but troubling all the same.
    Then last year the oven door would not open or close properly. It was not under warrenty, hinges had to replaced. This was a very expensive repair, and at no time did we mistreat the door. It was always seemed unaligned and even had it adjusted the first year by a service person. We see now on line that this is a common problem with the unit.
    Now, this year all of the igniters are malfunctioning, only one lights, but never stops clicking, the other 2 only click without lighting, and the 4th just does not work at all.
    On top of all this, the oven does not heat to the appropriate temperature. Though sporadic, this problem is becoming worse.
    We have read the troubleshooting guides, cleaning ,etc. Nothing helps. We do see that all of these problems are chronic and have been reported by others. Help
We inherited a 30 inch Viking Ultraline when we purchased our current house. I was extremely excited to cook on such a high-end range, but this thing has been nothing but trouble. The temperature on the oven is always between 25-75 degrees hotter than indicated on the dial. An oven thermometer is the way I solved that problem. None of the igniters work on the burners (I use a BBQ lighter on all the burners) the broiler has never worked, and one of the hinges broke and required replacement. We actually ordered the hinges off the internet for $25 each and replaced them ourselves--it was not complicated but would have been costly to get a tech out to do it.
After repairing the hinges, I decided to use the self-clean function, which, big surprise, not only did not work, but locked me out of the oven! I tried re-starting the self-clean, breaking the circuit and re-starting it and nothing worked. Having read many posts on the internet, I realized I would probably have to get a tech in to fix it for me. In desperation, I finally turned the oven on to 325 for 20 minutes, hoping it would unlock, and inexplicably, an hour after I turned it off, it unlocked itself. Finally, the burners are impossible to keep clean--no matter what I do to clean them, they always look filthy.
I would never buy another Viking product, as I am totally underwhelmed by the performance of this range.
Posted on Jan 22, 2010
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
I have a vikin 30 inch gas stove it been a problem for the last two years i had a repair man here four times. The problem is the oven will not light and when it does and then meets the desired temp and...
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Jul 08, 2011 | Viking VGSC366-6B Gas Kitchen Range
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
The ignition of the oven is erratic. Some times it won't ignite. sometimes it dosen't ever reach temperature. sometimes it work as expected. Sometimes it will ignate if one of the(stove top) burners is...
NO LONGER NEED ASSISTANCE. FURTHER RESEARCH ON THE INTERNET DISCOVERED OTHER STOVE OWNERS WITH THE SAME PROBLEM. IGNITOR REPLACEMENT FIXED THEIR PROBLEM. I'VE ORDERED THE PARTS.
Jan 23, 2010 | Viking VGIC305-4B Gas Kitchen Range
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking Ultraline Professional Gas stove
It is visible the hinges /w40 has extension nozzle spray the hinges a few minutes open slowly/ by moving little by little until the lubricant or oil penetrate the moving parts of hinges ,
Jan 01, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Kitchen Ranges Logo
1,309 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
