Question about Home
I own my trailer but is on a rental lot-i have water coming up around toliet and sewage up into the tub. We just recently had the main line under trailer jet sprayed. What do i need to do? if i replace the seal under the toliet will it stop the problem? who would be responsible for the payment-me or landlord?
  • 760 Answers
If the toilet to the floor flange wax seal is leaking that is your problem, it's your trailer. Most likely it would have leaked, but since there was no blockage, it just kept going down. Now you have blockage either in your system, or in the park's sewer system. You said you had your main drain jet sprayed, did that help or for awhile? Depending on how many bathrooms you have, usually in a trailer the main drain is near the main bathroom. If you have sewage backing up in your tub, then the whole line is backing up. If you have a long run under the trailer before it goes into the ground, make sure it is open and enough fall. If it's in the ground, then it's the park's problem. Have the park clean the line from where you connect. Any neighbors ahveing problems? Does your sewer line go to a septic tank or a treatment system.
Posted on Jul 20, 2010
Water smells like sewage
The drain is connected to the sewage system, so the smell could come from there, install a trap valve
Mar 29, 2013 | H2O Audio H20 Vac Turbo Water Filtration...
Would a vent problem cause the water to back up in the tub and cause the toliet to bubble?
A vent would cause an odor problem but not a back up problem. There should be a clean out between the house and septic tank, if it is full the blockage is down the line, if its dry the blockage is in the house.
Nov 20, 2012 | Dishwashers
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
Whirlpool LHW0050PQ4 Solenoid Failure? Problem started yesterday after 4 years of dependable usage. After a load was completed and the "Done" light on, I opened the (unlocked) door and...
the water control is by a diaphragm that is controlled by a solenoid
when the solenoid is activated , a small needle unblocks a hole and the diaphragm opens to allow flow
when the water is shut off the needle blocks the hole and the incoming water closes the diaphragm off so stopping flow.
sand will affect that operation so new valves ($20.00 approx ) will fix that problem or maybe just pulling the diaphragm section off and cleaning it out
next the filters in the inlet hoses are under the rubber washers so pull the washer out and the filter will come out
next if you have a mains supply problem, the answer is to fit a big blue filter ( 4" X 20" ) paper element filter to the house supply line
that will filter out any dirt and rubbish down to 10 microns and if you go a carbon filter down to around 3 microns ( around hair thickness size)plus and taste
as for the water in the tub problem , you may have to get a technician in as that would be the program not shutting of the inlet water while spinning or a pump not operating correctly ---blocked inlet or inlet filter
Feb 28, 2017 | Whirlpool LHW0050PQ Front Load Washer
We bought a home and our spare bathroom shower does not work. we replaced the moen valve and still cannot get water to come out of the shower. the toliet and sink in that bathroom work as they should. and...
did you install the valve sideways or upside down? or is there a blockage in the hot line? the valve may be pressure balanced so if there is no water then there may be a blockage on one side. did you solder the valve? if so did you remove the cartridge? when you replaced the cartridge did you grease it with non-petroleum grease?
Dec 03, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Apr 25, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
Toto toilet has weak flush
Check water level in tank and also under rim off toliet bowl where water come's out. Make sure level in tank is right and it has ports all around rim. they can be clogged up also.
You can use a roofing nail to stick in ports it is several around under rim that you can't see but are there where water comes out. Because if the ports some are stopped up it will restrict proper amount of water to certain areas.
Apr 13, 2010 | Toto Aquia II Dual Flush Toilet
Can bottom of bathtub collapse
The answer is yes.Most of your moble homes have poly or fiberglass tubs with litttle or no bracing under them and the floors are made out of a fiber type board. When they get wet they warp, crumble and fall apart, so if water has gotten under the tub there isn't much of a floor under it. But yes it can be repaired. She will have to remove the old tub and the wall board around it And probably have that portion of floor replaced.
Dec 02, 2009 | Home
Home Logo
75 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
