The cold water seems blocked and wont fill up the machine. What do I need to do?
  • kmedina33 Jan 08, 2009
    I have an old Whirlpool that won't fill on the cold wash and cold rinse portions of the cycle, but warm or hot water fills just fine. Further, if I start on warm or hot and then switch to cold, the washer seems to fill OK. Any help would be greatly appreciated
I don't have voltage on the vaulve. What then?
Posted on Jun 16, 2011
    Genius:
  • 1,073 Answers
If no cold water then check the water inlet valve for possible obstruction at screen in the valve or the fill hose it may have a screen in it
if not the problem the verify that you have voltage to the water valve if you do replace the water inlet valve
Posted on Apr 21, 2008
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
Washing machine wont fill fast enough
Is your water line blocked? if I just do a cold water wash, the water comes in slower then if I have it on warm.
Mar 04, 2015 | Washing Machines
Why wont my washing machine advance to rinse cycle?
Does it drain? If not check the lid switch. If it does make sure the cold water inlet screen isn't blocked. Most washers have only cold rinse, if screen is blocked or there is no cold water it won't fill and then won't advance.
Aug 30, 2014 | Washing Machines
My washing machine is over filling it is draining away but only if you put it on a spin the inlet water is constant and is always filling and wont cut off then it leaks from door seal and tray for washing...
Water inlet is controlled by a level switch and hot/cold water valves,( solenoids). It seems most likely that one of the water valve diaphragms is faulty;turn off hot and then cold taps to determine which one is leaking.A handy person can often strip the valve and replace the diaphragm, or else
a service person may be needed.
At times, the water is measured by weight,(depth) and during spray rinse by the timer, therefore, if you are using a cold rinse, ,most likely the cold valve is faulty.
Jul 24, 2011 | Washing Machines
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
The washer will not fill with cold water. When I try to wash with cold or warm...only hot water will fill the machine.
If it is a hot and cold fill washer, then you must ensure that there is water at the inlet valve, and the valve filter is not blocked.
If that is o/k, then the valve could be faulty.
Also ensure that you have the cold water connected to the cold valve if it is hot and cold fill.
Please rate my solutioin.
Thanks.
Nov 20, 2009 | Office Equipment & Supplies
Washing machine will not run on cold water ...will not fill or operate when cold water is selected. Temp selector switch or fill valve??
Check the water filter to see if it is possibly blocked. Shut-ff off the water valve on the cold side, then disconnect the cold water hose to get to the cone shaped filter. Pull the filter out and see if it is blocked.
Aug 21, 2009 | Washing Machines
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Feb 07, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
