Question about Toshiba Qosmio G15-AV501/R Notebook
Toshiba Satellite P100 PA3237U-2aca adapter pinout
Can anybody tell me what the pinout is for the P100 power adapter? I am working on a P100 and don't have the adapter, so I was going to connect 15vdc to it but don't know which pins to connect to.
Thanks
  • Darrell Kittle Jr
    Darrell Kittle Jr May 11, 2010
    On the board or the dc jack?
harvester3
  • 181 Answers
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Posted on Feb 09, 2008
SOURCE: Toshiba Satellite L25-S119 Does not Power on
The Toshiba laptops are famous for the power jack wriggling loose from the motherboard. Once it gets so loose the adapter power stops and it uses battery power until that runs out. You can usually move the power cord around until it starts working again but this is just a temporary fix and the jack will eventually need to be replaced. Most computer shops charge between 100-250 bucks for this service.
Posted on Jul 17, 2008
babes_ganda0
  • 381 Answers
SOURCE: I have a Toshiba Satellite Laptop Model A15-S129
hello..if you need to run @ safe the unit only up to 16v 2amp DC u need to try input..do not try higher from 16v DC or Lower 15v DC..or you need buy a new..Thanks And Good Luck...^_^
Posted on May 17, 2009
  • 226 Answers
SOURCE: I NEED THE PINOUT FOR THE TOSHIBA SATELLITE A40
the top 2 pins (narrower portion of the connector) are power (15V), and the bottom 2 pins (wider portion of the connector) are ground.
Posted on Apr 10, 2011
  • 16 Answers
SOURCE: nec versa 4230: What is 4 pin adapter pinout ?
It is 13.5 v dc.
When viewing the end of the cable that connects to computer with the centered notch up, upper left and lower right are positive.
Upper right is negative (per the labeling on back of ac adapter),
Posted on Jul 20, 2011
It will not power with battery
the battery charger circuit is short circuit, therefore need to repair or test the battery is ok
Aug 13, 2017 | Toshiba Satellite P100 Notebook
TOSHIBA p100 LAPTOP SREEN DEAD AFTER BIOS UPGRADE
Purchase a new EEPROM with a good BIOS loaded. I suspect the anti virus programme was not disabled and has stopped the new firmware from loading, leaving a corrupt EEPROM.
Mar 23, 2013 | Toshiba Satellite P100-429m Laptop DC Car...
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
How to check out or look for problems with the lcd monitor on toshiba satellite p100
The internal screen is faulty. Check the inverter first. (under the display).
Jan 20, 2013 | Toshiba Satellite P100-102 P100-103...
Can i change graphics card for toshiba p100 -347
The card is part of the main board, but you can likely add one to the expansion slot if it has one.
Mar 22, 2012 | Toshiba Satellite P100-347 Laptop DC Car...
Hello! how do I test if output is correct from PA3237, Toshiba PA3237U, Toshiba PA3237U-1ACA, Toshiba PA3237U-2ACA. I have a laptop not charging / powering unless I hold the part of the charger cord...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 17, 2011 | Toshiba PA3237 PA3237U PA3237U-1ACA...
Toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Apr 12, 2009 | Toshiba Satellite P100 Notebook
A brobblem with my chrger
Here is the replacement Toshiba Satellite A75-S209 A75-S2112 AC Power ..
Part number: PA3290U-2ACA, or PA3290E-2ACA
Dec 20, 2008 | Toshiba Satellite A75-S209 Notebook
Computers & Internet Logo
324 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
