Question about Intellinet Active Networking Computers & Internet
I have a intellinrt broadband router and switch and i did something and it does not work any more
    Brigadier General:
  • 3,917 Answers
Hi
Usually the way to reset the router to the factory settings is to push in and hold the re-set button for more than 4 seconds. The reset button will be located at a small hole on the back and might require you to use a small pen or screwdriver to push it. Just push the button until all the lights re-set and this should bring it back to the factory settings. After you have done this then you will be able to use the factory password to get into the router. The default user name will be "admin" password is "1234"
Please check this bellow sites to install your broadband router…
http://assets.mhint.s3.amazonaws.com/downloads/736/503693_QSG.pdf
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
Check the IP address on that computer.
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the router settings.
Please check this useful link….
http://sites.google.com/site/networkguidedemo/home
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 20, 2010
My router needs password to reinatall it all i get is access denied what sould i do
First you can try the default username and password, both are "admin". If that doesn't work you'll need to reset the router. On the back there is a small hole with the reset button inside. Use something small like a pin or paperclip to push that reset button down. Hold it in for 30 seconds. This will reset all of the router settings. Then use the username and password "admin" to login.
Mar 14, 2011 | Port Designs Linksys Wireless-G Broadband...
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
Wireless-G Broadband Router port forwarding
Need Model and Version number of your Linksys router. To find this info look at Tag on the bottom of your router, look for something like this WRT54G V8 (Model/Version). After that we can help you fix your problem. Thanks!
Oct 10, 2010 | Linksys Wireless-G Broadband Router
Problem with 2wire adaptor connecting to Avenue Broadband
Yes, The DSL connection and Broadband connection are different with each other.
You'll needing to reconfigure the router as Dynamic and clone the MAC address so that it will recognize to the network.
- Try resetting the router and reconfigure the settings of your router.
Mar 05, 2009 | 2wire HomePortal 100 Network Adapter
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Need to connect router to deck top.comp.
This might work for you. Now to go in and configure the router thats something totally different.
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
How to activate port # 3 on my Wireless-G Router
I had the same problem and finally decided the router was failing. I bought a new router. It will be interesting to see if somebody tells us we had something incorrectly configured.
Dec 19, 2007 | Linksys Wireless-G Broadband Router
Not making a connection to broadband router
Hi, If I understand you right, you installed a hub after your router, all your PCS are connected to the hub and it is working. Then you should not be concerned, first, you did right, second, as long as it works and isn't slow or disconnecting then no issues. A few buts: 1. If your router has 4 ports, then you don't need the CP3008a and 2. why only "2 lights on cp3008a" if you have 2 PCS + the router, you should have 3 lights; At the end of the day,if it works and you have no complain, let it be. Kind regards.
Aug 24, 2007 | Accton Refurbished CHEETAHHUB POWER-3008A...
Computers & Internet Logo
97 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Prashant M
Prashant M
Tech support
Tech support
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
