Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
Hello I have a Husquvarna 125L trimmer manufactured in 2007. A part has failed in the starter cup assembly because when I try to crank the trimmer it does not engage and simply turns free. I have the trimmer disassembled to the starter cup. The information I need is the procedure to remove the coupling starter screw in order to remove the starter cup. The screw has an allen head. Is the screw a left hand thread or right hand thread? How do I keep the crank shaft from turning when the screw is removed? Do I use an impact wrench or do I use a regular allen wrench? I have included a link to an engine parts diagram. The parts include numbers 12, 13, 14, and 15. Your help would be greatly appreciated. http://www.partstree.com/parts/?lc=husqvarna&mn=125+L+%282008-01%29&dn=35_10_0005 Thanks
    Problem Solver:
  • 6 Answers
Have had same problem. This is a very old post so this is for those who have this problem. It is part 15 from the link given up there. WARNING I AM NOT A MECHANIC OR WELL VERSED!!What happens when you pull the handle is two starter couplings(plastic) engage the shaft that engages the engine. When it starts these fall free and allow the engine to spin freely. When they break the engine isn't harmed. You need a star head screw driver and NOT a phillips. Just he two on either side of the starter cup. Don't think you need to take off all 8 or more screws. Just the two. Pull out the other coupling. They just pop in. Buy 2 new ones. The other one is probably compromised anyways. Husqvarna 530059800
Coupling-Starter. Not a very involved process at all. Two screws. Pull off cup. pull out white plastic couplings. Put in new ones. Put the cup and screws back on.
Posted on Oct 06, 2010
Need a husquvarna user manual model 125L
the model number 125L is for a trimmer according to husquvarna and here is the link for that manual, http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=125L&types=O
if you have a riding mower that link can help you locate a manual as well but you may need other numbers located on your mower. If Ii can help you please contact me.
Thank you.
Jun 26, 2011 | Husqvarna Garden
I have a husqvarna 125L trimmer. I need to get the starter cup off. It's held by a coupling nut. How do I lock the shaft and which way do you turn the nut (left or right hand thread)?
Its a clockwise thread to undo the bolt,you need to put a small bar in the gear head tho to stop it turning. You may have the type of gear head that you hold the top of the shaft with a spanner
May 03, 2011 | Husqvarna Garden
I have having problem with my Hysqvaran 125L with the pull cord. When i pulls cord, it not catching the trans and it sound like the spring is not catching?
Hi and welcome to FixYa, I am Kelly.
It sounds like the starter cup has failed / broken. See this link: (Page 3 item 14.)
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2008/HIPL2008_5450143-15.pdf
However... the pawls on the starter pulley (item 28 above) may have broken.
There is a whole kit for repairing the starter recoil: PN 545180844
That can be found here:
http://cgi.ebay.com/HUSQVARNA-RECOIL-STARTER-KIT-124L-125L-128L-545180844-/150485511147
Your need to remove the starter recoil assy and check for damage. It will be obvious. Just remove the mounting screws and lift it off. It is not difficult. Use the first link page 3 to identify the parts you may need once you do the visual inspection with the recoil removed.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | Husqvarna 28cc Gas Line Trimmer
My 125l starts and runs for 5 minutes, then stops dead. trying to pull the started, it seems jammed. I took off the recoil starter and turned the engine over with a wench (torx I believe) which was...
If the engine is a concern, run a compression check. All you will need for this test is a compression tester (small engine) and to remove the spark plug. It should be at least 90psi or above as I recall. A lot of times, people have "scored" their engines and they don't know it.. I don't suspect that is your problem. Compression test is a real good indicator of your internal engine's condition.
Sep 23, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
I HAVE A 125L HUSQVARNA TRIMMER. THE RECOIL STARTER WAS FINE, THEN STARTED MAKING A RATCHETING SOUND SOME OF THE TIME BUT WOULD NOT PULL THE ENGINE THROUGH AND START IT OTHER TIMES, NOW IT MAKES THE...
Actually, there are two solutions, did not see the two nubs on parts diagram either but I have done some extensive research and the nubs come with the cup assembly. One solution is to go to partstree.com and order part # 545102303 or part # 545180844. Both come with the white plastic nubs and springs. Also, what I did with mine if you are tech savy is cut off the stem that goes through the black cup, drill an 1/8th in hole through the bottom of the plastic nub and then assemble nub and spring and secure putting a screw through the hole in the bottom of the black cup, securing the nub. All you are doing is replacing the part of the nub that goes through the plastic cup with a screw. You are pre drilling the hole in the nub so you dont crack the nub with the screw. Make sure the screw is straight so you dont get too close to the edges or it will crack. This method takes crafty hands and good eyesight. If done correctly, they will never pop out again. Promise!
May 09, 2010 | Husqvarna 28cc Gas Line Trimmer
What is the oil to gas ratio for the husqvarna 125l weed eater
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Apr 10, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Husquvarna 125L Won't stay running
Check the gas cap vent. If it's clogged, it will cause these symptoms. This problem tends to be more acute if the tank is fulll.
These symptoms are also typical of a leakng crankshaft oil seal. On a small 2-cycle, this needs to be gas tight. If it is not, loss of primary compression will result, causing your symptoms.
Oct 02, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
445 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
