Hi I honeywell,rth63oo b electronics thermo stat how do o change the accuracy from + - 1% to + - 3% Thankx
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
The following are the two manuals for ths product, I looked briefly and didn't see an answer to your wuestion. If you want to change the number of degrees between heating and cooling operation from 1 to 3 degress that can be found in the operating manual, under programming. 69-1723 - RTH6300B - Programmable Thermostat Operating Manual
69-1717 - RTH6300B Programmable Thermostat Installation Guide
Posted on Jul 20, 2010
Don't remember security code on thermostat
All Honeywell t-stats have a model # and a 1-800 #. Call them! Have your t-stat apart to see the model#. Or if you don't know how to take it apart call them first. Ask Mr. Google for Honeywell customer service #. Their customer service is usually %100 in helping me when needed.
May 25, 2015 | Honeywell THX9421R5005 Prestige IAQ...
I don't remember the security code to change the settings.
Depends on what t-stat you have. Need a make of tstat and model # or style.
Can i use th5320u1001 on 2 stage compressor and 1 stage heat? tom roll , abe service company , bowling green,ky
Yes, that t-stat has that capability...
http://www.pexsupply.com/Honeywell-TH5320U1001-The-FocusPRO-Non-Programmable-Digital-Thermostat-Premier-White-4956000-p
If you need the manual to get it set up then check out this tip...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 15, 2010 | Honeywell Electronic Programmable...
My honeywell t-stat reaches current temp setting and furnace kicks off...but within 1 minute the t-stat drops 1 degree and the freakin furnace kicks on! This can't be right as it has never happened with...
Your differential is set to close you can go into tstat and change differential setting. Your install manual for your thermostat will tell you how you can set 1.2.3 degrees differential
Dec 13, 2009 | Honeywell Electronic Programmable...
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Radiators cold when thermo says otherwise !
First, check to see if the battery in the stat is good. If you can move the manual temp up and down...causing the relay to click on and off, the unit ought to work. If not the battery is bad or the stat is. IF THE UNIT IS ON 110V, you can't do the following:
If this is a two wire connection, simply short them out. If the heat comes on, the stat is bad. If not, the relay package is likely defective. You may want to get help from someone who knows electrical items.
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
