Question about Refrigerators
I have whirlpool refrigetor ,now its not working?
    Genius:
  • 1,073 Answers
What is not working
Posted on Apr 22, 2008
Hi, I have subzero side by side refrigetor. Building up on back panel on refrigetor side . I defrost it clean and in week again ice building up ? Ho to resolve ? Thanks
check aall your seals on your doors and make sure they are sealing tight. Your compressor is working extra hard and freezing up. Also check the thermostat and make sure its not turned down to low, that will also cause compressor to run hard
Oct 09, 2015 | Refrigerators
Whirpool refrigetor compresser run for a few second and turn off
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Whirlpool Refrigerators
My fridge is freezing food
HI,IF YOU REFRIGETOR IS FREEZING FOOD CHECK YOUR TEMP CONTROL OR THERMOSTAT AND THE AUTODAMPER (airflow control) PROPERLY CONDITION,,IF THE TEMP CONTROL IS BAD THE COMPRESSOR WILL BE WORKING ALL THE TIME,IF THE AUTODAMPER IS BAD WILL BE COOLING TOO MUCH..
Feb 21, 2011 | Refrigerators
My Whirlpool Refrigetor's copmressor is continuesly on , what is solution , is there is problem with thermostat
Yes since your compressor is running continuosly the first case of the fault could be the thermostat. So you might have to trace the wires to the thermostat including the bimetal / sensor. Check for breaks in the wires as due to frost build up the wires may disintegrate in due time. If not you will have to go with confirming the thermostat. Hope your fridge is working fine otherwise and you have not noticed any other anomalies because if the compressor runs continuosly the cooling can also drop which will therby make a chain reaction for not lettting the thermostat reach the temperature. So inthis case the timer could also be a suspect. So please check all these factors. Good day
Aug 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Refrigetor service centre in kolkata
Please check on the website of Whirlpool for all service centres located in your region.there is a toll free number where you can register your complaint and get follow up. Chek this out. Helpful ? Have a nice day.
Jul 02, 2010 | Whirlpool ED2FHEXN Side by Side...
The deforst timer didn't work and got ice
Does the timer move? If you can, try rotating the timer to the defrost postion when the frigorator turns off and see if the defrost emement starts to heat up. If it doesn't then you could have a bad thermostate. easy to replace.
Jul 15, 2009 | Whirlpool ED5FTGX Side by Side...
Refrigetor doesn't freezer
small appliances use CLOSED systems because they use r-12 or 134a freon (you have to be licensed to buy and dispose of it) - once charged - they are sealed shut. You will have to make your own charging port with a tap (similar to a refrigerator water line tap. They are available at most A/C supply shops... however the taps are inconsequential if you do not have a license to purchase the refrigerant.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 02, 2009 | Refrigerators
Wirlpool refrigetor model ed2chqxkl05
try these tips. http://www.hometips.com/home_probsolver/hps03/09_refrig/hps_refrig09.html
Aug 23, 2008 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
