Question about Bosch WAS24460UC Front Load Washer
My bosch washer (WAS24460UC) fails to start. I close door select program but when I press start - it beeps flashes and doesn't start. I wonder if there's an issue with the door registering as closed?
We have the same problem - did you find out what the problem was?
Posted on Nov 30, 2010
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Unable to use washer due to key logo 'flashing'. Have checked the plug at bottom right of machine no blockage there.
Please try this
the key and flashing = child lock.
close washing machine door, turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Than You
Sep 08, 2010 | Bosch Classixx WFL 2066 Front Load Washer
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WAS24460UC Front Load Washer Logo
266 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
