Question about RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer
Pilot will light, goes out when button let go,
Pilot will light, goes out when pilot button let go, replaced the pilot / thermocouple assy, same issue, also cleaned the flame aresstor, same issue ?
This is a GCV-50-101 propane unit.
I started going out for two weeks, but was able to restart, until it wouldn't stay lit all together.
My propane tank has 500 gallions with 80 PSI showing - i also ohmed out the gas valve checking for no open in the 2 leads.
OK- want to advise while I was posting this I removed my thermo, reinstalled, no help then noticed the RED GAS KNOB had a slight crack in it allowing it depressed enough to start the pilot but not far enough to enguage the thermo. removed the knob used small plyers to push down shaft-hold-let up and BAM works fine knobless.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
A long time ago, in a place far away, I saw an old gas valve, might have been on a water heater, might have been off an A/C unit. I took my 10" adjustable wrench and unscrewed the coil that the thermocouple screws into. Now, when I have the problem that you describe I take the threaded end of the suspected thermocouple and put it into my spare. I light the pilot and hold the button down. Then, after a minute or two, I press the button on my spare, which now has the thermocouple attached. If the spare stays in the "ON" condition, I have just proven my gas valve to have faulted.
I suspect you main gas valve has failed, if you can find another valve, you can test as above, before buying a replacement valve.
Posted on Jul 20, 2010
Testimonial: "it was related to the gas valve but the actual control knob itself- thanks"
We have an atwood lp gas water heater 6 gallon g6a7 white rogers control. The pilot lights but when we turn it to on it goes out, even after holding it up to a minute. It was running fine, we thought we...
If pilot stay lit, then thermocouple is working.
If pilot will light, then you have gas. If pilot goes out when pilot button is released, then thermocouple is next suspect.
Thermocouple tip must sit in pilot flame.
The pilot light heat applied to two different metals inside thermocouple causes small current.
The current travels back to gas control valve through copper line.
If the gas valve receive this current, then a magnetic switch stays open and allows gas into the gas control valve.
The magnetic switch is on the end of the red button you push down when lighting pilot. Essentially the red button is an override to the magnetic switch.
If the gas control valve does not receive the current, then the magnetic switch does not stay open when you release the red button.
When replacing thermocouple, note that it is not screwed very tight into the gas control valve. Finger tight + 1/4 turn. If it is overtightened, then the small thermocouple current shorts out against the gas control body.
Sep 01, 2012 | Water Heaters
Pilot light would not light but i could hear and smell gas coming out of pilot valve so i took off cover and cleaned it. It still would not light with the ignitor button so I did it manually and there is a...
sounds like the thermocouple:
The thermocouple is a safety device that turns off the gas if there is no pilot light. If you look closely at the burning pilot light, there is a small metal tube that sits directly in the flame, with wires that lead back to the gas valve. The thermocouple generates a small amount of electrical current when heated by the flame. This current keeps the gas safety valve open. If the pilot light gets blown out, the current stops and the gas valve closes. When you light the pilot light, you hold down the over-ride button for about 30 seconds. This allows the gas to flow long enough to heat up the thermocouple and generate current and then you can release the over-ride button and gas will continue to flow. If the thermocouple is defective, then as soon as you release the over-ride button, since there is no electrical current, the gas will stop flowing and the pilot light will go out.
This is a pretty common failure on water heaters and furnaces. Replacement of the thermocouple is fairly simple if you are the handyman type. If not, the thermocouple is a cheap part -- about $10 bucks, but the service call may run you $100 or so. Before you call a serviceman, get all of the brand and model information from the information plate on the heater so he can bring the proper replacement part. And sorry for your trouble. hope this helps:)
Jul 28, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
The pilot light on our tankless water heater will not stay on.
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out
Sep 20, 2010 | Bosch Water Heaters
AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER IT LIGHT FOR A FEW SECONDS AND THE FLAME AND THE PILOT LIGHT GOES OUT. WHAT CAUSE THIS TO HAPPEN?
There is air in the gas line. The best way to get the air out, is with the gas on, loosen the nut that attaches to the gas valve and make sure you can smell a little gas, then reattach the gas line, making sure everything is tight, and then relight the pilot making sure to hold the pilot light button down for at least 1 minute. Please rate
May 24, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I cant get the pilot lit...I turn it to pilot...hold down the button and light the pilot..but when I let it go to turn it to "on" the flame goes out.
Are you holding the button down for a minute or so after you light the pilot before releasing the button?
If so, almost certainly, your thermocouple is bad. This is the long tube which runs from the control box to the pilot flame. Remove this tube, take it to the hardware store and get an exact replacement.
Once the thermocouple is replaced, your pilot light should stay on.
Apr 04, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light won't stay lit
Replace the thermocouple
Sep 25, 2009 | Water Heaters
My pilot light will light, but will not stay lit? I have a gas whirpool water heater aprox 1 1/2 years old.Thisis the first time we have encountered any problems with our appliance.
Once the flame has struck it heats up a thermocouple that in turn holds the gas valve open
It is a safety measure in case the flame blows out and the gas keeps on coming.
Sometimes the end of the thermocouple gets dirty and a scrub with a fine emery board does the trick
If not it is a new part (They are not that expensive)
Jul 07, 2009 | Whirlpool Water Heaters
Pilot light will not stay light
Check to see if the thermocouple tip is in line with the pilots flame, if its not heating the tip then carefully adjust as necessary. If the tip is in the flame and still wont stay lit then the thermocouple is due for a replacement.This task may require that the burner assy. be removed, so as to access the fasteners that attach thermocouple tip, hence disconnecting the gas line that leads to the burner, and must be properly reinstalled and leak tested. This item can be found at most hardware stores and home centers (Home depot/Lowes) be sure to gently remove the old one and take it with you (for comparison) when you are ready to purchase the new part.
Note: As with any repair of this nature, safety must come first, quality gloves and eye protection should be warn. also do not attempt any repair that is outside of your ability and knowledge.
Good luck...
Feb 22, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light won't stay alight, when i release the knob after lighting, the flame goes out.
hello!! if you changed the thermocouple & the pilot still goes out !! could be a thermostat ( the electromagnet pilot safety ) goes bad !! make sure pilot is clean & should be sharp BLUE pilot !! not yellow & soft !! also hold down the button light the pilot use a digital volt meter set on dc milivolts a brand new thermocouple should test @ 30 milivolts+ - ! & if you have new style water htr with sealed combustion the thermocouple has a safety part of it ! change the thermocouple & make sure your vents for combustion air around the bottom of the water htr has lint & dust built up !!! kiddbrother i work for a gas company doing service !!
Dec 14, 2008 | Rheem 36" Water Heater Thermocouple Kit
RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer Logo
457 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
