Question about Acer TravelMate 2480 Notebook
I need to try to replace my cooling fan and heat sink, I have tried to get the back of the computer off, I have removed the HD and battery and all the screws, but it still seems to be held by something near where the battrey slides in, How do you take the back off the computer to get at the cooling fane and tube and heat sink?
    President:
  • 1,138 Answers
Watch this video about dis assembly of Acer 2480 Notebook
This will be your guide
http://www.youtube.com/watch?v=0toDoK8uL2I
Posted on Jul 20, 2010
    Brigadier General:
  • 4,044 Answers
Actually there is a lot yet you have to open. Check the battery compartment for hidden screws, also there should be a cover near the top by the screen that will come up. You are going to have to remove that and then remove the screws holding the keyboard down and the Hinge Screws. After that most likely you will need to remove the screws holding the motherboard down so you can lift the motherboard out so you can access the cooling fans and coils. Acers like to use built in clips that are molded into the body of the laptop as well, look for some of those.
How to replace cpu cooling fan on HP pavillion MS227 desk top pc
to REplace the heat sink of the HP pavillion MS227 All in one model ..you have to remove the stand on the back,and remove the plactick that cove the whole screen try to use some tool that very shap edge to get through the lock to break out very carefully if you don't want to break the cover.there are some screw that you may need to remove too..but not alot,than after you can get the cover out you should see the madal plate that cover the main board and heat sink,,need to take that out..yo should be able to replace the heat sink from HP MS227 all in on or any of other HP All in one model too...Before you replace the new one make sure you clean youe CPU by use some alcohol to clean it goog and new heat sink need to clean too..need some Thermal compund to put on top of CPU..get it from some PC sale and service...to reduce heat from your CPU...than you ready to go...hope it can help..
Jan 12, 2012 | Computers & Internet
IBM x3400 server hanging / chipset & processor heating, but cooling fans are working properly.
Make sure that the fans are working at proper speed (not stuck or slow).
Secondly, heat sink could be clogged due to dust or not properly seated. Clean it if required. You may remove it, clean its fins and replace it back (for both processors if required) . Don't forget to apply THERMAL PASTE between the heat sink and the processor (If you remove the heat sink). The Thermal paste conduct the heat from the processor to heat sink which is then dissipated into air by the processor fan. You may also consider adding an additional fan, if required.
Also, place the PC at a well ventilated location so that the cool air enters it from the front and warm air leaves from the back.
Sep 26, 2011 | IBM x3400 Server
Cpu over temperature error cpu temp : 39 to 101 mb temp : 30 to 100
First step would be to check all cooling fans are running correctly. Second blow out the dust and debris from inside the computer. If the cooling fans are not running correctly you will need to replace them. Thrid have you added any new hardware or have cables that would interfere with airflow? If so move things around so you have good air flow around the processor. Finally (before we get into the professional portion) you might try adding additional fans to the case, there are fans that will go in a drive bay to help improve air flow.
CAUTION!!!! The following steps should only be taken by a competent professional:
1. Check the heat sink, is there thermal paste leaking out around it (too much paste was used). You will need to remove the heat sink, clean up all thermal paste and then remount the heat sink with a small amount of thermal paste.
2. Remove the heat sink, is the thermal paste dried up? If so, inferior thermal paste was used. Clean up all the old thermal paste with alcohol, replace the heat sink with a small amount of good thermal paste.
Of course if you are running the computer in an 80 degree room, that will affect temperature too.
Hope this helps.
Jul 27, 2011 | ASUS P5LD2-VM Motherboard
Dell optiplex GX620 loud processor fan noise like a vaccum. I upgraded to windows 7 and also upgraded to 4gb of ram and a new hd video card as well as a 1tb hd. I bought 4 more gbs of ram but windows...
I don't think you can install 8gb of ram into that desktop. If the processor fan is too loud check it for dust or any other obstructions. If there aren't any try replacing the fan - it could be a bearing in the fan.
Mar 06, 2011 | Dell OptiPlex GX620 PC Desktop
I have a a Dell Studio 1536 with ATI Radeon HD 3200 graphics card. The laptop gets overheated very fast after working for 3-4 hours of continuous usage. Is there any way this problem could be...
This problem could be a faulty fan or most likely the fan and heat sink is clogged with dust.
Remove the dust from the fan and heat sink assembly and clear the hard to get places with a can of compressed air.
If you still have overheating problems and the Dell has vents on the bottom of the laptop. then you can use a laptop cooling pad (it has fans in the pad), place the laptop on this pad and it will get additional cooling from the fans in the cooling pad.
Dec 02, 2010 | Computers & Internet
My laptop is overheating and i think i need to remove the fan and dust it. What else can i do because the fan is not running at maximum capacity
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give a "blow-job" to every possible orifice and vent in the casing of your computer.
Reconnect the battery & the AC power.
Aug 16, 2010 | HP Mini 1000 Netbook
Laptop just shutting down every 5 mins or so -- Just going power down and booting up until one waits -- Same issue in safe mode, on battrey, on power with abttrey disconnected, and even in bios mode....
Sounds like the CPU is overheating. Try cleaning with canned air. On the bottem of the laptop you can see a fan with laptop off and battery removed use a whole can of air to clean it. wait 5 min. replace battery and try normal start up. listen for the fan to come on if it doesn't the fan is bad and needs to be replaced
Hope this helps
Please leave feed back
Nov 29, 2009 | HP Pavilion DV6910US Laptop
Laptop switched off while i was working on it
After the notebook shuts down do not turn it back on for 15 minutes and then test it again. Will the notebook work longer if you let it cool down for a while? Isn’t it hot if you touch the bottom? Can you hear the fan running?
Most likely you experience a laptop overheating problem and it would be fixed by cleaning the cooling module – the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on. The cooling module helps to keep the CPU cool when the laptop is working. The cooling module includes two parts: the heat sink and the cooling fan. The heat sink is attached to the CPU and helps to conduct the heat from the processor to the radiator. The cooling fan blows on the radiator and helps to disperse the heat produced by the CPU. The laptop will overheat if the heat sink radiator is clogged with lint and dust or if the cooling fan stopped spinning.
If your laptop shuts down after some time without any reason and warning, check if the cooling fan spins. Usually it makes some noise and you can hear it. If the fan works fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air, just blow inside the fan openings on the laptop bottom. If the heatsink is completely clogged, then it is necessary to remove the heatsink for cleaning.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!  uva
Mar 25, 2009 | Gateway 830GM PC Desktop
Acer TravelMate 2480 Notebook Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
