Question about Dishwashers
Gaffers & Sattler Model BDC420-1 Dishwasher Dimensions?
  • 125 Answers
SOURCE: Gaffers & Sattler stove
The pilot is under the bottom oven deck, usually you can lift the front edge, and slide it out, smelling gas without a pilot would be bad, that means either A : your safety is bad, and allowing gas to flow anyway, which requires replacement, and you may as well replace the thermocouple, and clean the pilot. or B : it is old enough it does not have a protected pilot, and you have to manually light it, usually indicated by an open hole in the front middle of the oven deck plate when you open the door, with a tube going to the burner. or C : your oven burner is bad or misaligned with the burner, and is shooting gas away from the pilot area, it would light via an open pilot eventually, but you don't want that. Please let us know, or have a qualified servicer look at it. Happy New Year, and thank you.
Posted on Dec 31, 2008
SOURCE: Can't find the oven pilot on an old Gaffers and
With the help from your site I was able to hold a match under the bar under the oven shelf toward the back and light the pilot. I am SO grateful. I hadn't been able to see it but just held a match toward the back, and it lit.
Posted on Mar 01, 2009
  • 222 Answers
SOURCE: stove-top burner grate is broken
I THINK NO AVAILABLE FOR REPLACE COZ IS FACEOUT MODEL AFTER 10YRS.ALSO U CANNOT REPAIR COZ EVERY TINE U USE WILL BROKEN AGAIN.
Posted on May 29, 2009
SOURCE: HEATING ELEMENT GAFFERS & SATTLER BUILT-IN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Posted on Nov 22, 2010
SOURCE: I have a 1965 gaffers
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Posted on Jan 06, 2011
?Location and photo of the transformer for a gaffers and sattler wall furnace model S 90 FE.
No. The transformer "transforms" 240 volts to 24. Meaning the high voltage coming into the machine. Normally has a "c",208,240 written on one side. Follow your main power wire into the machine. Branches to heater and transformer. Look at wiring diagram
Mar 01, 2017 | Heating & Cooling
Gaffers & Sattler stovetop model 1465/944. The burner mechanism malfunctioned when we turned the knob where it connects to the burner and is leaking gas and will not turn off. We would like to find...
Not that many parts for a 33 year old appliance are still avaiable but try one of these places
http://www.antiqueappliances.com/
http://ths.gardenweb.com/forums/load/antiques/msg0717405813237.html
http://www.facebook.com/pages/Vintage-appliance-restoration/124642017603277
http://www.stovelady.com/
I have been a appliance tech for 30 years and love the vintage appliances and strive to search for to repair them whenever possible if the customer wants to hold on to them
Good luck,
Gene
Aug 05, 2011 | Cooktops
Im having problems with my electric Gaffers Sattler stove. One of the burners is alwas on high when you turn it on. I cant find a serial number. Thank you for your time.
The switch that controls that burner is defective.
Pull out the lower pan drawer and look for a model number on the range cabinet.
If you can not find a model number,unplug the range,remove the switch and get a part number from the switch.
Jan 06, 2010 | Cooktops
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
Dec 22, 2009 | Ovens
Stove-top burner grate is broken
May 26, 2009 | Cooktops
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Have an older gaffers and sattler stove with microwave built into top. do you know what wattage the microwave is. tahnk you. Paulamrella@verizon.net
Check the manufacturer plate label on your microwave. It may be written like this- KW usually beside the Manufacturer model number.
You could also do a little calculation by checking the voltage and ampage readings. multiply them is going to give you wattage.
Jul 24, 2008 | Microwave Ovens
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
