Question about Delphi SKYFi3 XM Radio Receiver
My Delphi skyfi3 xm radio has stopped working, It seems to be in a freeze mode with the channel and signal strenth showing good but I am unable to command it to change. I have tried holding down the mode button on the radio and hitting the power button on the remote, but no luck.
    Brigadier General:
  • 3,917 Answers
Hi
Hold down "power" and "volume up" at the same time to do a reset. You need a 'firmware update' from the Delphi website. Also, you can call Delphi for help too.
What you need to do is simultaneously hold the VOLUME UP button as well as the MODE button. This will reset the unit.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 20, 2010
Skyfi3 freezes up on checking media
common problem! Press the volume UP and the Power button at the same time and it will go off. Go to the Delphi/XM website and upload/download the latest FIRMWARE and upgrade it. Then, call the 800 phone number for Delphi and they will tell you a secret master reset you have to do once or twice, and it will cut down the number of lockups during checking media by quite a bit. Also, do not use a Micro SD card larger than 2MB as well. Good luck, and let me know how it goes for you.
Aug 06, 2010 | Delphi SKYFi3 XM Radio Receiver
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
I have a XM delphi skyfi3 and I can record songs and listen to the radio portion fine. However, I cannot play my recorded music back on the my music mode, regardless of whether the xm is in the cradle or...
You must have a subscription and listen 'live' 8 hours a month, or it doesn't let you listen to recorded content anymore (thanks to the RIAA and their royalty fees to XM)
Jun 27, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
My xm radio is all lit up it shows all of the information but you can't change channels get into the menu or any other functions it is like it is locked up. any suggestions
May 07, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi3 display blank. manual power only briefly...
try plugging the DC adapter directly into the buttom of the SKYFI3 - do you still get some sort of a power warning?
Jan 20, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
No audio through car radio
is your car radio and the xm receiver tuned to the same frequency?
Aug 31, 2009 | Delphi SKYFi XM Radio Receiver
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
My xm skyfi3 is on and the buttons will not work It is frozen up and I cannot get it to turn off or do anything. I have checked the button lock switch and it is off
Try this: "Reset your SKYFi3 by pressing and holding the volume button and pressing the mode button" (from user guide page 62)
Dec 13, 2008 | Delphi SKYFi3 XM Radio Receiver
Downloading instructions Delphi SKYFi3 unit
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Oct 21, 2008 | Delphi SKYFi3 XM Radio Receiver
Skifi xm
click on the display button until it shows the channel name
Aug 19, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 XM Radio Receiver Logo
310 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
