If you have a good battery then the problem likely is the valve adjustment. I know it sounds crazy but if the valve lift is not set right it has too much compression. These engines have a compression release for when it is cranking to make the cranking easier. When the engine starts it goes off and runs normal. If you get that adjusted it will run like new. it is pretty cheap to have the shop do it too.
