Question about Sony STR-DA5000ES Receiver
When i hook my ps3 to the receiver i only get audio??
  • 757 Answers
Make sure that you have a connection from video out to the TV, from the input you are using for the PS3 on the receiver. The connection for video to the TV is labeled "monitor out" on the receiver. You can use one of the following for it; composite, component or S-video. Or...
Your best results however for your hardware, is to connect your PS3 directly to the TV, then connect the "audio out" from the TV to the receiver. Then select on the receiver the matching input you connected the audio to from the TV.
Posted on Jul 20, 2010
DENON AVR-1912 PS3 ISSUE
You might just have a handshaking issue between your PS3 and your receiver. See if there are any firmware upgrades for your PS3, Receiver or both. This usually takes care of the problem. If not - your receiver has a 2 or 3 year MFG Warranty. Have it checked out or exchanged.
May 02, 2012 | Denon AVR1912
I'm trying to hook up my playstation 3 to my receiver and i can't get video or audio when using fibre optic and hdmi. how do i hook this up properly to get the best possible video/audio?
Having both HDMI and Fiberoptic cables causes conflicts with one another, HDMI carries both video and audio signals HDMI = Best. Hook your PS3 to your audio source with HDMI. then configure it through your PS3
Feb 01, 2011 | Denon AVR688
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
Unable to get ps3 to play when hooked to receiver
The audio inputs on the receiver need to be set to receive the Optical signal on the switch you set the ps3 to. ie Game, DVD, AUX. Each switch needs to be set to receive the audio signal coming into it. Usually on the remotes setup feature.
Feb 10, 2009 | Denon AVR588 Receiver
No sound with ps3 hdmi hook up
Hey there, The same kinda thin happend with my surround sound have you checked under the audio options that the right cable is selected ?
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
No audio from PS3.
works great, plenty of plug-ins, easy set up, but you get 2 hdmi ins 1 out. hdmis' work great one cable for sound and video but the denon avr588 doesn't accept sound through the hdmi cable.(it's noted in the manual) why not? i don't understand. so you go with optical or coaxial for audio. it works but extra cables.
Dec 28, 2008 | Denon AVR588 Receiver
Hooking up a PS3 to my surround sound
you have to go to the set up menu and let the receiver know that you are inputting dvd audio to the digital in. (assigning). that way, when you switch the receiver to dvd, it will look for audio from the digital input. your receiver manual will guide you through that set-up.
if that does not work, the fiber optic cable could be bad. this is more common than people would expect.
another option is to just rca cables to the receiver from the ps3. there is an adapter that lets you do that.
good luck
mark
Dec 28, 2007 | Televison & Video
Sony STR-DA5000ES Receiver Logo
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
