Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have recently moved, the movers forgot to put the shipping bolt in my washer. I noticed the canister was tilted a bit when it was put in the new house. It still runs fine, should I be worried?
I did the samething! But I fixed my own. Take the back off and look for the springs thay have came off. By looking at the other ones (The ones that are still in place) you will know how to hook them.If there in the front take the bottom front panal off.You may have to replace it if its broke(springs).GOOD LUCK
Posted on Jul 24, 2010
    President:
  • 949 Answers
If it was hauled carefully and not dropped it usually is okay. Try loading it with a pretty full load of towels. If it spins up to full speed without excessive noise or vibration, everything is fine.
Posted on Jul 20, 2010
I recently moved and the movers removed two bolts from the back of the machine...should I replace those bolts
No do not replace the shipping bolts. I assume you have a front loading washer. The tub is secured by bolts during transport. Then they have to be removed so that the washer will operate properly without damaging the machine.
Many machine manuals are available online. For example, LG washers manuals are available at their site and under more information for models sold by Home Depot (http://www.homedepot.com/Appliances-Laundry-Clothing-Care-Washers-Front-Load-Washers/h_d1/N-5yc1vZ1xr5Zbv6h/h_d2/Navigation?langId=-1&storeId=10051&catalogId=10053&omni=c_Front%20Load%20Washers). The LG front loading washers use 4 bolts with retainers. If they are not removed, the machine will have severe vibration and noise. The vibration can damage the unit.
I hope this helps.
(if you have an top loading washer, shipping bolts are less common. If you provide the model of the washer, I'll see if it is one for which I know the shipping instructions.)
Dec 12, 2010 | Washing Machines
Do i need to put in shipping bolts to move my washer 600 miles and if so where do they go and what size bolt do i need?
The shipping bolts protect the washer tub from getting bounced around when the washer is moved. The shipping kit should have come with your washer when you purchased it. If you have misplaced it, you can find it here http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF2940ES-%3d%3di1170681&PartID=1170681
Hope this helps you.
Aug 31, 2010 | Frigidaire GLTF2940ES Front Load Washer
My LG front load washer bounces and is really loud during the spin cycle. I've tried balancing it in all directions and recently put a thick rubber, non-slip mat underneath but now it's moved the mat!
make sure all the shipping bolts are taken off and if they are you probably arent totally level but it sounds like the shipping bolts are still on there and that wont let the dryer level like its supposed to the bolts are usually on the bottom and usually have a tag saying remove after shipping
Feb 24, 2010 | Washing Machines
Recently moved and now my washer sounds like it is going to take off!
Hi.
If you hear an high pitched noise or rumble that becomes louder when spinning at speed, then you may have dislodged the drum bearing or broken the drum bearing spider.
The part is located at the back of the drum.
Dec 03, 2009 | LG WM-2277HW Front Load Washer
Where to get shipping bolts for wssh300g1ww
Hi Judy
Your best bet would be calling GE and see if there is a part number for those bolts and where you can get those.. Installer usually throw those away after installation..
Here is their tel #1 800 626 2000
Jun 29, 2017 | GE Washing Machines
Where to get shipping bolts and how to install them?
DEPENDING ON WHEN YOU MOVE TRY www.repairclinic.com LOOK FOR ITEM NUMBER 912239 USING THE MODEL NUMBER YOU POSTED
Apr 07, 2009 | GE WSXH208A Front Load Washer
Missing shipping bolts
if you are moving and you are using a dolly to move it than you dont need shipping bolts. i del. preowned washers and dryers everyday and never put shipping bolts back in just becareful and use your head and you will not hurt anything.dont bounce it down stairs either it is a 2 person job so dont forget to get some help
Jan 30, 2009 | LG WM-2077C Front Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Move
you can reuse the shhipping bolts but getting them back in is a royal pain in the but. if you have help you can have someone open the door to move the tub around so you can line up the shipping bolts to screw them back in. it help to take the top off the washer to help you see where your putting them.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
49 people viewed this question
Sal De
fordexpert
Robert Rankin
