Question about Garmin nuvi 260W GPS Receiver
I have a garmin nuvia 265wt Gps and I would like to update my maps is there any help on how to do this
  • Garmin Master
  • 6,993 Answers
Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
I hope this helps
Best regards.
Posted on Jul 21, 2010
Says to download receiver update...how do I
I can help you reset and fix your Garmin Nuvi 265WT.
Not starting, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
If you have run the WebUpdate, and the Nuvi isn't performing correctly, run the Hard Reset step again. This is detailed in the steps above.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Apr 17, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Garmin Nuvi 265WT Webupdate Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Does your Garmin Nuvi 265WT GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Backup & Restore Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 19, 2010 | Garmin n?vi 265WT Car GPS Receiver
My garmin nuvi won't turn on? i've tried to plug it into charger but nothing happens
Erratic behavior is an indication that the firmware / system software inside your GPS has been corrupted.
It is not necessary for your computer to be able to 'see' your Nuvi in order for the firmware update to work. When it is successfully updated, the Nuvi will communicate properly to the computer, and your pc will 'see' it, and you can load your maps.
I hope that helps.
Nuvi 265WT Change Home Phone Number
Nuvi 265WT Delete Phone Numbers
Apr 10, 2010 | Garmin nuvi 265 Car GPS Receiver
Cant unlock maps
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
Sometimes, a Hard Reset after the WebUpdate is what is required; that information is covered in the details through the links above.
I hope that helps.
Nuvi 265W Manuals here.
Feb 10, 2010 | Garmin nuvi 265WT Car GPS Receiver
After a map update my garmin 265 wont talk
I recommend reupdating your Nuvi 265WT with the newest firmware, and then performing the Hard Reset a second time afterwards to ensure the 'voice' functions come back on.
I hope that helps.
Oct 01, 2009 | Garmin n?vi 265WT Car GPS Receiver
Garmin screen freeze
I hope that helps.
Sep 03, 2009 | Garmin n?vi 265WT Car GPS Receiver
When I connect my 265wt to the computer, it just keeps loading the maps and the computer won't reconize the nuvi.
It is not necessary for your computer to be able to 'see' your Nuvi in order for the firmware update to work. When it is successfully updated, the Nuvi will communicate properly to the computer, and your pc wil;l 'see' it, and you can load your maps.
I hope that helps.
May 12, 2009 | Garmin n?vi 265WT Car GPS Receiver
No maps found when updating garmin with latest maps
I hope that helps.
Apr 12, 2009 | Garmin n?vi 265WT Car GPS Receiver
My garmin 265wt lost the map and audio while in use
I hope that helps.
Apr 07, 2009 | Garmin n?vi 265WT Car GPS Receiver
Frozen on 'loading...' page during registration
I hope that helps.
Jan 30, 2009 | Garmin n?vi 265WT Car GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
111 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
