Question about Sony Cybershot S650 Digital Camera
I have DSC-W90. When I turn it on, it continuely extendss and then closes the lense. Then after a several times doing this, it displays to turn off and turn on the camera. I have done this several times, but no dice.
  • georgesiecko Jul 20, 2010
    Yes, very helpful and quick to respond.
  • 10,594 Answers
There is sensor inside lens mechanism that sends mechanism initialize signal to system control chip of camera, if that signal is missing due to defective sensor, system control chip try three times to extend and retract lens mechanism then activate protection mode and shows error message on lcd screen as you see it "turns power off and turn it On again"
Lens assembly need to be replaced in your DSC-W90 camera to fix the problem.
Let me know if you need part number of lens assembly for this camera or take it in local camera repair shop for fix.
Hope these info will help you.
Thanks.
Posted on Jul 20, 2010
  • 8 more comments
    What is the part #?
    Thank you
  • Shahid Electronics
    Shahid Electronics Jul 20, 2010
    Part number of lens assembly in DSC-W90 is as follows:
    A1231924A .... LSV-1160A Lens Assy
    Available in Sony Part Store for $74
    Part # not found
    Found it. Sorry.
    My mistake, sorry.
    Click HERE then put part number in search box and hit red search button to get info.
    How technical does one need to be to replace this part?
    OK, great.
    Let me know if you have additional question.
    Thanks.
    Well he should not be novice and can take apart camera without damaging it.
    Thank you. I guess it will not be me replacing the part. I usually make things worse.
    haha,
    local camera repair shop is better to replace lens assembly.
IAM TRYING TO TURN ON MY SONY DSC-W90 CAMERA BUT DOST NOT TURN ON AND LENCE FREQUNLY TRY TO OPEN CLOSE AND I RECEIVED MESSAGE ON LCD DISPLY TRUN THE POWER OFF AND ON AGAIN , EVEN I REMOVED AND FIX BATTRY...
The error message is due to the lens issue. the lens might have stuck due to moisture condensation or dust. It may require service to resolve the issue.
If you wish to resolve it yourself, you may use a soft cloth to clear the dust by manually pulling out the lens part..
If it doen't help, it may require opening the Camera
Jan 22, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
How to change date and time setting in Sony DSC W290 digital camera
Turn on the camera
select a setting item with up or down arrow
select date and time format
select daylight savings
then set date & time
Aug 30, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
Problems with flash
In certain modes, the flash settings cannot be changed. Select a different mode.
Jul 26, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
When turning camera on lense opens then closes several times then the screene says to turn the power off and on again. Is there a fix for this?
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Lense will not retract
Try to move it manually. If not succesfull, I am afraid you have to let lens replace.
Sep 19, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera reset for w90 and w200 sony
If camera is DSC-W90 and DSC-W200, go to camera menu and select Initialize -> OK
That will Reset camera to factory default settings.
Feb 23, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Sony cyber shot dsc-w90
If you've tried whacking it, maybe you didn't whack hard enough. get a hammer. whack it about five times.
Aug 07, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
DSC W80.
Whenever you switch on the camera the lense comes out to a certain places, stops and the camera is initialized to take the picture. In some cases when there is a friction in the movement of the lense, it does not comes out fully up to the proper position. so the camera mechanism draws it back and again pushes it out. this happens 3-4 times and if still the lense does not reaches its position it displays "turn the power off and on again" and the problem continues.
Your camera needs a repair of the lense assembly.
Jul 08, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
DSC-W90 Sony Digital Camera - Lens Error
Sorry man, I think you're out of luck. Most likely nothing you can service, maybe a professional can fix it though. Still under warranty? Good luck.
Nov 09, 2007 | Cameras
Sony Cybershot S650 Digital Camera Logo
81 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
