Question about Mtd 22" Yard Machine Push Mower
Broken pull cord mtd lawnflite mower
How do remove coil to replace cord
  • 40 Answers
SOURCE: broken starter cord MTD Model 125-478R062
try this link.
http://www.smallenginesuppliers.com/shop/html/broken_starter_rope.html
you will want use size #4 or 4.5 starter rope. about 7 foot in length.
Posted on Mar 18, 2009
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
Dolfoff
  • 148 Answers
SOURCE: how to remove and replace rear wheel tire on my
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
How to remove the rear wheels from a mtd lawnflite ride on mower
they just need bumped off after the bolt is removed .they will be rusty so some penetrating oil will help a lot
Feb 17, 2015 | Mtd Garden
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
I have an mtd. Lawnflite model 135-668-352 and need a belt, but can't seem to find one. Can u help?
There are two belts in this parts list (and 6 other parts lists for your model) on this site:
Parts and Diagrams for MTD Lawnflite Mdl 668 352
May 20, 2014 | Garden
How to replace pull cord
The pull cord is in the top cover to your engine.
Remove top cover and any attachments such as oil filler tube and fuel tank. With cover off you will see the old cord or whats left of it. Remove old cord. Put tension on the spring by turning the coil assembly. Put the pull handle on one end of cord, and insert the other end of the rope into the coil assembly. Let the cord retract into the coil assembly. This should do it. GOOD LUCK>
Jun 28, 2011 | Mtd Garden
Where can I find the diagram for the cutting deck belt routing for an MTD Lawnflite tractor mower 13AA478E678
Hi go onto the powerhouse site below, put in your mower details and you will see the plans for the deck.
Geoff
www.powertoolspares.com/...lawnflite.../906-13af765n611-1998-576/
Oct 19, 2010 | Garden
Trying to replace ext spring on lawnflite 548 can't get the spring to stretch the last inch.
You don't specify which spring but if you take a piece of starter cord, tie it in a loop and hook it on the loose end of the spring, put in a long screwdriver, a piece of broom handle or anything similar, it will give you a lot more leverage to pull the spring. Once you get it to where it needs to go, you can maneuver it to get it hooked then just cut the rope and pull it out
Sep 12, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
What size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
Jul 20, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
252 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
