Question about Pioneer DVR-220 DVD Recorder
I own a Pioneer DVR-220 dvd recorder and my problem is that the unit will not power up. I've tried disconnecting the ac power cord from the Monster Power power source and connecting the power cord via an extension cord to a verifiable source of power. But that doesn't provide power either. Any suggestions?
  • 3 Answers
I replaced two capacitors, (1) 10 volt, 1000uf and 10 volt 3300uf..They both sit on the power board that can be removed from the unit..You will have to unsolder the bad capacitors and put in the replacements..This wasn't hard to do...
Posted on Aug 12, 2010
DVD player powers on and then returns to standby mode
hi richard.
i have had a look around the internet but all i could find was the is link.but when you go to it its forums that you can go into.so not to sure if it will be off any use,but have a look.
Pioneer DVR 220 DVD Recorder powers on and then returns to standby mode...
Nov 07, 2017 | Pioneer DVR-220 DVD Recorder
My Pioneer DVR 320 dvd recorder just stopped working. Iv'e checked the power source thats Ok. Is their a fuse or something or is it old age?
Tries unplug,replug the unit back like about an hour later,see if might just in it protected mode,see if the unit reset itself and work again.Yes,there is a fuse in the back of the PCB board,it seat near the power a/c cord.U can tries to replaced the fuse and tries it out.But all modern electronic devices saldum burn fuses in a normal uses.
Jan 29, 2011 | Pioneer DVR-320S DVD Recorder
No power
First check, the AC line where you plug your DVD.Then, check the power cord ,If nothing is change. open it,check the power supply section. checthe power supply section.
Aug 25, 2010 | Pioneer DVR-320S DVD Recorder
Can irecord on my dvr 220 pioneer from my new freeview tv
Yes you can do this. You just need to make sure that the TV outputs its picture on the scart lead that you have connected to the Pioneer unit, and you need to set the Pioneer unit to record from that scart input. Once this is done, it will be able to record whatever you have on the screen. Be aware though, if you turn off the TV it stops outputting its picture to the recorder, and if you change channel, it changes what what the recorder see's too. I hope this helps you. :)
Jul 20, 2010 | Pioneer DVR-220 DVD Recorder
Pioneer DVR-220 will not power up. Any suggestions.
First check the in line fuse...it sits right behind the electric plug on the chase..You have to remove the screws to open the case to check this....If the fuse is okay, you will have to replace these two capacitors, 10 volt, 3300uf, and 10 volt 1000uf...they are located on the same board that houses the fuse...the two location are c23 and c19 on the power board...
Jul 08, 2010 | Pioneer DVR-220 DVD Recorder
Random power failure
completely disconnect the power cord 15 mn and then reconnects, It's a power problem i think that is the condensators which are out of service
Sep 27, 2009 | Pioneer DVR-520H DVD Recorder
Power off after recording
Hi All,
This is a power supply problem.... the MR2920 stanby IC miss behaved, it power off and fail to power back on.
Solution, get pioneer power supply replacement or take the dvd recorder to your local electronic service repair to take a look at the power supply circuit.
Best of luck
Kenny
Apr 21, 2009 | Pioneer DVR-520H DVD Recorder
Open Questions:
Pioneer DVR-220 DVD Recorder Logo
377 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
