Question about Element Electronics FLX3210 32 in. LCD TV
When i turn on the tv the power light is on but the backlight doesnt turn on. Does that mean i need a lamp?
  • 11,361 Answers
Posted on Jul 20, 2010
Sharp lcd tv turning on, sharp logo comes up then it powers off
can be backlight issue. lamp defective in lcd screen. try to force on unplug tv .and then press and hold volume - channel+ and input buttons on tv while holding down these buttons then plug in in. will come on .its mean lamp defective.
Apr 25, 2017 | Sharp Televison & Video
When I turn the tv on it came on for a minute then started flashing on and off then went blank but the power light keep flashing off and on with a blank screen.
This problem is easy to repair. If when you turned the tv on and it had sound and picture for a second or two, and the power went off and the power green light keeps flashing on and off, it is a bad CCFL backlight lamp inside the LCD panel which has 10 of these lamps in it, but only one is bad. Replace the lamp and the tv will power on. What the tv is doing is, it has stored a lamp error code on the main board and turning the power off. The replacement lamp is part # RLMPLA029WJN1 and you can buy them at www.encompassparts.com for $19.49 ea. Go to their web sight and sign in as guess to order. I can give you step to step instruction on how to check how many lamps you will have to order if you need me, too. You will have to take the tv apart to check them.
Aug 03, 2011 | Sharp LC-32SB23U 32 in. LCD TV
My sharp aquos lc-c3242u turned itself off and now wont turn back on. i plugged it into a different power receptacle and the green light flashes but wont turn on. is there a way to reset the tv, or is...
If power light continuously flashing it means backlight problem. Two possible causes. One, backlight invertor is faulty. Two, but realy rare, one of the CCFL lamps went bad.
Dec 02, 2009 | Sharp Televison & Video
How to FIX
Televisions have protection circuits which prevent full power-on if a fault is detected in a high voltage/high current circuit such as the backlight inverter.
Some googling on 'Sony Blink Codes' found that 4 blinks is 'backlight failure'. A common failure in LCD displays is the backlight inverter board which is a transformer similar in function to a fluorescent light ballast, as the backlights are fluorescent lamps.
If the screen color is getting pinkish/reddish, that's a sign that one or more of the lamps themselves are going bad.
Since multiple lamps are connected to (typically) two inverter boards (a primary and secondary board), I am fairly certain that the blink code refers to a failed inverter board and not a failed lamp.
Oct 19, 2009 | Televison & Video
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Screen displays no signal after a power failure; can hear sound, no picture
It's either the backlight lamp or backlight light inverter is busted due to the power failure.Here's how to determine which is which:
  2. Turn on the TV.
Sep 25, 2009 | LG 42LC2D 42 in. LCD HDTV
The green light is on ,the red light is on over the temp, and red
your backlight might be burned out same thing happen to my grandfathers and it turned out to be the backlight was burned out just call company if its a sony number is 1800-345-7669 sorry i dont know other companies
Jan 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv wont turn on
I have a pile of these in my shop. Unfortunately and usually, a backlight lamp is bad, and the inverter board is damaged when it goes out. The backlight lamps are sealed inside the panel, so the usual method of repair is to replace the panel.
If you turn the lights off in the room, then turn the tv on, you will probably see a momentary flash of light from the backlight trying to start up. The lamps can be replaced, but the option is not really cost effective given the amount of time it takes to replace them/very delicate nature of the lamps/availability of the lamps/cost of the lamps. Replacement panels might be available, but you'd have to use a TV shop for reference or call Sanyo directly.
These units also have a history of power supply heat damage, so if you don't see the momentary flash, it could be the power supply. But the momentary flash is the dead giveaway.
I hope this helps you...
Dec 30, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 screen black no sound screen flashes when turned on
Hello, I just posted this to another user's question, and you might find it useful, too.
Dec 10, 2008 | Sanyo DP32746 32 in. LCD Television
Element Electronics FLX3210 32 in. LCD TV Logo
242 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
