Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Fuel problems The fuel is not getting to the filter
    Sergeant:
  • 200 Answers
The fuel line is probably clogged or stopped up try cleaning it out.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
Running rough
Most likely it would be the fuel filter. Sometimes debris can get stuck in the filter and clog it up. Letting it sit lets debris settle hence the cold start being fine. I suggest changing the fuel filter. If that does not fix the problem change the pump also. If you are looking for a slim chance but possible cheap fix try putting some fuel injector cleaner through the system. This might fix the problem even if it is the fuel filter but be warned it is a temporary fix and the fuel injector cleaner does leave a gummy substance on the fuel filter and might make your problem worse. So if you choose this route you should change your fuel filter in the not to distant future.
Mar 23, 2014 | 1995 Chevrolet K1500
Polan pro bvm200vs711923 will not start. Has compression. sparkplug is new and shows spark. Seems to have fuel. Note: The fuel line in in the tank for the primer bulb is not present, nothing beyond...
Looks like it's the fuel filter in the tank, the filter will be in the tank at the end of the line.
get a stiff wire, make a hook at the end and fish for the fuel line that has the fuel filter.
you will have two fuel lines in the tank one has a fuel filter, that's the one you want,
once you remove the fuel filter, submerge the fuel line in the gas, and primer the bulb
if the bulb gets full of fuel, theirs your problem, sometimes the filter can be cleaned
with an air compressor, but sometimes its so dirty that it,s better replaced to prevent
further problems. good luck!
Jul 27, 2011 | Poulan Garden
Tractor is not getting fuel pass the fuel fi;ter...new filter
Check the fuel lines,fuel pre-filter[screener] and check valve,all of these are ahead of the fuel filter.Also if the fuel filter is not the problem then the primer pump on top of the filter housing may have a leak or debris in the diaphragm so that you can not get the fuel to completely fill the filter.Once the filter is full,full fuel out of the bleed screw on the filter housing,then you need to turn on the key and keep on pumping the hand primer.If it still will not start then get a 11/16 wrench and crack two lines on the injection pump.Crank over the tractor until it sounds like it may go,tighten the lines,the crank again and it should start.
Jul 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Fuel filter cloged up and stopped running. changed filter and now running rough truck has 210070 milles always ran great untill filter cloged any tips
Most of the time,when the fuel filter stops up,it puts a strain on the fuel pump,and the fuel pump gets weak from trying to run,and most likely in your case this has happened.You will have to replace the pump,to fix the problem,but have the fuel pressure test done just to make sure,if this was helpful,please rate,and thank you.
Jun 10, 2010 | 2000 GMC Sierra
I haVE A 1987 HONDA CIVIC CRX WHEN I GET ON THE FREEWAY AND GET UP TO 65 MPH IT STARTS TO STALL OUT LIKE ITS NOT GETTING GAS I HAVE TO LET OFF THE GAS THEN IT SARTS TO RUN SMOOTHLY. I HAV E REVED THE...
SOUND LIKE FUEL FILTER OR WEAK PUMP.IF YOU HAVE CARBURETOR FUEL FILTER IN REAR UNDER THE CAR IN FRONT OF SPARE TIRE FRONT IN LINE FILTER IS LOCATED AT THE CARBURETOR.IF YOU HAVE FUEL INJECTION ENGINE FUEL FILTER LOCATION IS ON FIREWALL IN THE ENGINE COMPARTMENT.IF FILTER CHANGE DONT STOP STALLING PROBLEM COULD BE IDLE SPEED TOO LOW AND FUEL PUMP TOO WEAK NOT PUMPING ENOUGH FUEL FOR HIGH SPEED DRIVING.
Jun 04, 2010 | Honda CRX Cars & Trucks
Engine not getting fuel
First, confirm that the fuel filter is clean. Next determine that the electric fuel pump (usually located in the fuel tank) is operating. You can do this when you check your fuel filter. With the filter out, turn on the ignition (DO NOT CRANK THE ENGINE). The fuel pump should run and fuel should flow out of the fuel filter holder .... or the fuel line if it is an inline filter. Be extremely careful and have somebody help with this test because you could be pumping raw gasoline into the engine compartment and on the ground. If the filter is clean and you are getting fuel out of the fuel line then the problem could be an engine computer or the fuel injection system.
Nov 27, 2009 | 2001 Kia Sportage
1990 subaru legacy has fuel starvation problem where in cold weather fuel stops reaching fuel filter. Car stops and generally turning ignition back on starts pump and sending fule to fuel filter. Have...
Did you end up getting this fixed? Mine (same model, year) has a similar problem. I used a fuel additive to clean out the whole fuel system, carburetor, combustion chambers etc and it's helped heaps. But still struggles a little in the cold, still need to leave it running for a few mins before driving. About to replace the fuel filter now and see if it helps...
Oct 16, 2009 | 1986 Subaru Gl 2 Door
Hi i have a '95 lincoln mark 8, and recently i have had problems starting my car, it tries to start but wont crank over, but i only have this problem some times, the past couple of days i have'nt had any...
two things to check, when was the late time you had a tune-up done ??? next, get a fuel pressure tester. hook up to the fuel rail. key on, engine off, pressure could be at least 35 - 45 PSI. get a hanes manual #59010. it will help you troubleshoot. fuel filter is a good place to start. should replace filter every 2 years.
Oct 15, 2009 | 1995 Lincoln Mark VIII
Cannot get 1987 chevy van 20 to keep running... stalls out
Best do a fuel pressure test. Should have chg. fuel filter from the get go. The only other filter is on the end of the fuel pump in tank. Bad gas and dirty gas will plug up fuel filter, hense burn pump up.
Apr 11, 2009 | 1987 Chevrolet G20
Fuel problem on diesel truck
Hi.,
I guess your truck is getting air in the fuel system.
When you bleeding, work a few minutes until get more air.
The fuel filter on a GMC or Chevy diesel.
Need to be positioned the element and the gasket.
I Recomend put a New filter But. I recomend get the filter original A/C delco.
I had involved in a same problem. due a aftermarket fuel filters.
I hope this information work for you. THank you for use fixya.
Jul 15, 2008 | 1999 Chevrolet Venture
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
61 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
