Question about GE WSXH208A Front Load Washer
How do you perform the monthly basket clean on a GE front loader
  • 18 Answers
SOURCE: my GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Posted on Aug 09, 2009
  • 6 Answers
SOURCE: I have a GCVH6260FWW GE Front Loader. It will not
Yes you should see it - and call an electrician they can legally disconnect the "water saver" or adjust it safely
Posted on May 24, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: moldy smell inside GE profle top loader washer
Check the pump and make sure that it is draining the water. There will always be a little water left over but you should never be able to hear it very easily. Once you check the pump and make sure it is operating properly check the water sensor to make sure that it is acuratly reading the water hieght. After that take one cup of Vinegar and run a hot load of water will kill the mold and clean your system out
Posted on Feb 21, 2009
SOURCE: my ge front loader washer will not drain
We had same problem. The pump was all clogged up with fabric debris, and a part of a metal bra liner. I removed the pump and cleaned it out. Now it seems to work fine, and went through a complete cycle. Ther pump was accessed from the front, and was not too hard to remove.
Posted on Mar 01, 2009
  • 714 Answers
SOURCE: smell in ss wash basket. Tried bleach, tide
go to smellywasher.com try some!
Posted on Feb 28, 2010
Where is front loader pump located, washer wont drain water, cleaned the filter ,want 2 look at pump 2 c if its good, cant find it
You simply take the 3 screws out from under the front lip. AND THE PUMP IS SITTING RIGHT THERE IN FRONT OF YOU SHOULD LOOK LIKE THIS
put a cake pan under the lip of the drain and unscrew the filter to take out the stinky water. Once it won't unscrew anymore pull the filter out and clean. OR PULL THE ENTIRE PUMP OUT TO PERFORM A INSPECTION OF THE PUMP
Nov 14, 2010 | GE WCVH6260F Front Load Washer
There is a musty oder coming from inside washing machine.
Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
Good Luck
Aug 08, 2009 | General Electric WBVH6240HWW Front Load...
Front load washer will not drain water
I had thesame problem with my from end loader, and the problem was that there was 6 month worth of change,crayons, and lint cloging up the drain valve. At the bottom of my washer there was a small cover, some are located higher than others but open it up, there will be a cover to turn,DO NOT OPEN untill you have something to catch the water that is going to rush out. Open slowly. then there will be a basket take out the basket clean it out and put everything back properly tighten the cover. And this should fix it!
Jul 02, 2009 | GE Energy Star WCVH6260F Front Load Washer
May 19, 2009 | GE WSXH208A Front Load Washer
Stinky clothes
you should run a empty load with bleach but no detergent every month or so to clean the washer, I also recommend cleaning the boot (door gasket) every couple of loads with windex or other cleaner. also every load check inside the bottom of the boot and make sure the drain holes (x3) are clear of lint, etc. this is normal maintenance for any front loader. GE is a very good brand and is my preferred brand, I repair appliances everyday, Whirlpool keeps me busy. I have GE front loaders in my house.
2nd poster, you will need a door hinge for this most likely. Not too hard.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell inside GE profle top loader washer
Feb 21, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE front loader shakes when trying to spin
try putting either a piece of plywood under the machine so that all 4 legs are standing on it or using plastic floor protectors that fit under each leg to see if you can get it to be more level. Have you ensured that each leg is in full contact with the floor?
Feb 06, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
Feb 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
I just got a brand new GE Front Loader Washer & Dryer.
No, but it depends on in part on what cycle you selected. Did you happen to choose one with an extra rinse cycle?
Jan 22, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE WSXH208A Front Load Washer Logo
1,296 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
