Question about Jabra BT350 Bluetooth Headset Headset
I am having trouble disconnecting a head set from a phone. My dad got a new bluetooth and gave me his, but we can't figure out how to disconnect the bluetooth from his phone, but we did erase it from his phone. It is just that the bloothtooth is still connected to his and it will not allow it to hook up to my phone.
You might try going to settings and tools on phone and press CONNECTIONS. Should take you to 1. incoming call 2. bluetooth....press bluetooth then handsfree. Should bring you to a comment of Bluetooth Power is On. Temporarily Power Off? Press yes. I hope this works for you.
Posted on Apr 22, 2008
I have lost my cell phone. I have a new cell phone. How do I disconnect my jabra stone 2 bluetooth from the lost phone and connect it to the new one?
hi jorene_crock,
You are in luck!
you do not have to worry about your old phone being disconnected from your headset! just connect the head set from your new phone like you did with you old phone :)
I hope this helps, good luck!
Mar 17, 2011 | Jabra BT125 Headset
How do I get bluetooth to work in my car which is already equippe
actually bluetooth will work only at a distance of 10m radius...so if u r using u r bluetooth while drivin u may be exceeding that 10m which leads to disconnection of u r bluetooth...so i advice u that use u r bluetooth when u r in home or at u r workplace...its after all a bluetooth connection...its not u r phone network to follow u wherever u go!
Jul 14, 2009 | Sony Ericsson W910i Cellular Phone
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
How do i connect my HBH-600 bluetooth headset to my phone?
hi thanks for using fixya!
Connecting a Bluetooth headset or hands-free speaker unit to your phone involves setting the headset to “discoverable” mode; check the headset manual for how this is done, as it varies by type and model. You’ll also need to find the headset PIN code in its manual – this is usually 0000 or 1234, but again it varies.
Go to Bluetooth menu – from the main menu highlight Settings (Figure 1), click Select, and scroll right to highlight the Connectivity tab. Highlight Bluetooth (Figure 2), click Select and then highlight Handsfree (Figure 3) and click Select.
When prompted to ‘Add a handsfree device’, choose Yes (Figure 4), and your phone will look for all discoverable hands-free units (Figire 5). Select the one that you want from the list that appears and enter the hands-free unit’s PIN code when prompted. The pairing will now be complete.
Once paired, you’ll find the headset listed under the My devices menu in the Bluetooth settings area, from where you can connect and disconnect it.
Hope it will help you. If you need further assistance, let me know!
Regards!
Apr 30, 2009 | Sony Ericsson Akono HBH-600 Consumer...
My cect phone P168 is permanently in mute.What can l do?
if head set is connected you will be headset mode (disconnect head set) go to profiles select (general, bluetooth, outdoors or whatever) customize how you want it, be sure to activate.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select Explorer 220 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth head set
4.Select HS850 once a connection is detected.
Tips:
Sep 22, 2008 | Motorola Mobility Universal Wireless...
Bluetooth
You don't need to disconnect to use the phone. As long as your phone bluetooth is set up. You can dial from your phone and leave it on your ear as it is also a speaker. When you close the flap it disconnects the bluetooth from the phone
Feb 02, 2008 | Motorola Mobility Bluetooth Hands Free...
Can't Pair With Phone
I had the same thing happen twice just recently and had to call my network and have them walk through some steps over the phone with me. They had to have me enter some numbers they gave me while talking to them and it came on. Be sure to call from a different phone than the one you are having the problem with. I also had it happen again a few weeks ago and I just removed the battery from my cell after disconnecting the bluetooth and then when I put it back together and reconnected the bluetooth it worked fine. I have had it for over a year and never had any trouble with it until this.
Jan 20, 2008 | LG HBM 730 Bluetooth Headset Wireless...
I Can't disconnect my Head set from my previous phone.
You have to go to your old phone and delete the bluetooth device from it or turn it off, then pair it up with your new phone.
Feb 10, 2007 | Jabra BT150 Wireless Headset
Jabra BT350 Bluetooth Headset Headset Logo
91 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
