Question about Toro Garden
Lawn mower was outside all winter with no oil in it. i was going to trash it because the oil pan nut was stripped. however, after buying liquid weld, i stopped the oil from leaking out. bought new spark plug, etc. however, the engine will not start and sometimes the pull cord "snaps" back hard !!! ideas ??
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Pos problem is that then piston may have rusted so will not crank. If this has happened you can try and take the head of and try and clean it but it may not be worth it in the long run
Posted on Jul 26, 2010
How do I remove a stripped lug nut from an oil pan on a 2003 Ford Windstar
Need a pic to be able to help you. I'd soak it with PB BLASTER or Liquid Wrench penetrating oil, then hit the surrounding boss,not the oil plug, with a propane torch for a few seconds.
Sometimes you can drive the next smaller socket(metric onto SAE or vice-versa) onto the plug.
A shop can weld a new bolthead to it and get a fresh grip. Unhook both battery cables,unplug the computer, and ground the car body if welding is done. At least that's what I'd do. don-ohio (:^)
Dec 31, 2016 | 2003 Ford Windstar
Lawn mower will not start after winter
did you drain all you gas out before winterize.
May 10, 2014 | Garden
Striped oil pan plug(renault megane 2)how to remove oil pan ,what tool to use?
they make a plastic plug that will fit in a stripped hole on most oilpans..autozone carries these as do most autoparts stores..it uses a screwdriverlike tool to insert or remove..in cold weather it needs warmed up before insertion or it will rip apart..warm it in hot tap water..there are also certain tricks to repair these..a good welder can fix it fairly well..weld a fine thread nut over the hole and put the corresponding bolt in the nut..good luck..
Dec 08, 2013 | 1998 Chrysler Concorde
Trying to remove a stripped oil drain plug on an 85 Ford Bronco
I would remove the oil pan, as I have
several times, & weld on a new nut inside
the pan, then you'll never have the problem
again
Mar 12, 2013 | Cars & Trucks
How do you replace stripped oil plug on a 1999 dodge caravan
Most people will tell you to go to the auto
parts store and buy an over size drain plug
Your choice
I remove ALL my oil pans, in that situation,
and silver braze (weld) a permanent thread
inside the oil pan
Dec 21, 2010 | 1999 Dodge Caravan
Lawn mower will not start i put fuel in the oil housing by mistake drain it all out and now it does not run
try flushing the oil and let it dry out but make sure you use the nut on bottom of lawn mower so you don't get any liquid in the cylinder. also try cleaning the cylinder.
Jun 20, 2009 | Garden
Can't find oil drain plug on eager-1 mower It's a craftsman with a briggs and stratton engine
Disconnect the sparkplug andf ground it. Turn the push mower on it side and scrap away all the grass from under the deck and look for the plug. If you cannot find one, drain the oil out from  the fill tube into a pan, buy turning it onto it's side into the pan.
May 06, 2009 | Garden
Garden Logo
66 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
