Question about Coleman Powermate 11 Gallon Air Compressor
I have a Cleman 4 Gallon, 1.75 HP, Powermate air
I have a Cleman 4 Gallon, 1.75 HP, Powermate air compressor that, when started, hums and then trips the breaker. I have removed the capacitor and had it professionally tested and it is not defective. Any help is appreciated.
Thanks.
  • 2,100 Answers
When mine hums and trips, it is one of two things, Not warm enough, only does this when it is cold out, and 2 would be not enough juice, I have to have a 20 amp breaker or it doesn't run. And if I use a cord, it has to big. The slightest drop in amperage and it will not run, yours might have the same problem, mine is only 1 1/2 HP. It draws some 16 amps at start up and then idles down to 13 to run. A 15 amp breaker, forget it. Cold out, forget it. It wasn't just mine though, we did a house last winter and made one bathroom heated with a gas heater with 3 compressors in there just to keep them warm, there was no room for us. Hope this helps.
Posted on Jul 20, 2010
    Master:
    Sergeant:
  • 411 Answers
Bad wires in start winding or starter points fused together, centrifical
switch not working
Posted on Oct 10, 2011
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
With pressure in the tank, the compressor will not restart. The electric motor tries to turn but cannot and will eventually trip the breaker.
make sure the bleeder unload the pressure when the compressor stops.if not it will be too hard for the motor to start ,it will drive too much amps and trip the breaker.just after its stops you can also unscrew the air line to see if it still under pressure(it will be a 1/4 nylon or copper line)if the air is comming out STEADY from this line replace you check valve.hope this will help.
Apr 29, 2011 | Coleman Powermate 60 Gallon Air Compressor
I have the Coleman Powermate 11 gallon air compresser, and it just stopped working. I checked all the connections inside, it doesnt need oil, thats one of the new technologies they gave it I guess. Doesn't...
A lot of motors have circuit breakers built into them--look for a push button on the end of the motor shell opposite the shaft end and push it in. If it clicks, then retry to start. If the button doesn't exist, or has no effect, try to turn the compressor by hand (power shut off). It should turn fairly easily. Most compressor motors use a capacitor to allow more power at start--if bad the motor will not run, but will hum loudly until the circuit breaker trips. Be sure to check the circuit breaker for the circuit that the machine is connected to. It's possible that the air pressure switch has failed causing no start. Hope some of this helps!
Sep 29, 2010 | Coleman Powermate 11 Gallon Air Compressor
Motor hums dont start
sears craftsman air compressor motor hums. replaced start capacitor still hums
Mar 13, 2010 | Clarke Power Products Inc AC2001 2HP 4...
HI; How do i change the brushes in an electric
Motors with carbon brush can be detected due to the two brush access at two opposite sides. Open this up,
and you can already change the carbon brush.
However, if your motor doesn't brush access, the probability is your motor is a capacitor motor. Replacing
the capacitors will restore your motor proper speed.
Oct 27, 2009 | Coleman Powermate 4 Gallon Air Compressor
Will not start
Hi
Keep it simple, have you pushed the reset button?
Ther may also be a master push / pull switch on the switch housing.
Aug 09, 2009 | Coleman Powermate 02 - Gallon Air...
Coleman 11 gallon air compressor wont start
Sometimes the initial start up with the tank at 0 psi electric power is adequate. However when the tank is full or the garage is cold it is a bigger load for start up. Check your overload (reset button) and breaker. If 220 volts one side of the breaker could be tripped without showing.
Feb 14, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman Powermate 11 Gallon Air Compressor Logo
303 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
