Question about Kenmore Washing Machines
I have a kenmore Series 90 washer and in the rinse cycle the water dribbles out. Filling the tub in the wash cycle is no problem.
  • Bob Henry Jul 27, 2010
    Yes, my washer is up and running. Thank you very much
    President:
  • 949 Answers
The symptoms you describe are consistent with a clogged water inlet. I would suspect the cold side.
If you have a temperature selection knob turn it to a cold wash and start a cycle. See if it just dribbles in there. If so that is the problem for sure.
Turn the washer off and unplug the power cord. Behind the washer are 3 hoses. 1 for the drain (larger of the 3) and 2 for the incoming water (smaller 2). Where the two smaller connect to the washer there should be a 'C' and 'H' stamped or marked on the back. Turn the valve off on the wall for the cold hose. Take the cold hose off at the washer. Put the hose in a bucket and turn the valve on the wall back on. Flush this hose until it runs clear. If it dribbles out from there it is a problem with the house water valve and you need a plumber, if it runs fast out there, look inside the fitting that the cold hose was connected to on the washer, if it is plugged up clean out the debris and reconnect the hose. If it still dribbles you will need to replace the water inlet valve on the washer.
Let me know if you have questions
Phil
Posted on Jul 20, 2010
  • 2 more comments
  • Bob Henry Jul 21, 2010
    That was not it. I have plenty a pressure going through the hose. I have tried to take the back of but that is no easy task. Do you have any tricks and any other suggestions for my problem of poor water flow.
  • Philip Jul 21, 2010
    If the hose has lots of pressure then the water valve on the machine will need replaced. The valve is attached to the back of the machine but accessible by taking the front cabinet off. Here is a website that has a good video on taking the cabinet off so you can get to the valve internally.
    Washer Cabinet
  • Bob Henry Jul 22, 2010
    Thanks Phil, that video really helped. I have taken the valve off and hopefully will get it replaced today. I will let you know.
  • Philip Jul 23, 2010
    Great, let me know if you need more help.
    Phil
My Kenmore washer fills correctly and then agitates. But it won't stop filling to then switch to the rinse cycle.
Your wash machine doesn't know that the tub is full. Open up your console and look for a vinyl tube attached to your water level switch. Take the tube off of the switch and blow into the tube to clear out any blockages. Then, put the tube back on and test the wash machine. If the problem persists, then you need to replace your water level pressure switch AND the vinyl tube (just in case it has a small hole in it somewhere along the way).
You can buy the switch, which comes with the tube, here:
Switch W10337780
Oct 24, 2014 | Kenmore series 90 Washer Motor 3951550-
Tip
We have a Kenmore 90 series hvy duty top loader, it works fine in wash cycle but...
This advice is for all Whirlpool manufactured TOP LOADING washing machines. This includes Kenmore, Estate and Roper models as well. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the white plastic lid switch connector plug. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located adjacent to one of the lid hinges in the rear.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first (this is the end of the clip with the 90 degree bend), and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
I hope this information is helpful..
on Jul 26, 2010 | Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Kenmore washer. At rinse cycle only, water fills very slowly.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore Washing Machines
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Washer Is Dribbling Water Into Tub
you have a bad inlet waer valve stuck in open position, youll need to replace the valve. easy enough to do, its the valve your hoses are screwed into, in the mean time until repair is made, you can simply turn offf water supply between loads ( not a bad thing to do anyway)
Apr 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
