Question about Refrigerators
It stops blowing cold air into the refridge part. The freezer part ices over. I have to remove the inside panel & defrost it because the coils are iced over. Works wonderful for about 2 wks, then I have to do it again.
    Genius:
  • 1,073 Answers
You have a defrosting issue defrost timer, defrost heater, or defrost bimetal is bad one of these parts will be the issue
Posted on Apr 21, 2008
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
I got LG fridge freezer my freezer has ice building and the temp is warm WHAT COULD BE THE PROBLEM. kclakhani@hotmail.co.uk
your defrost system isnt working and you cant blow cold air thru a solid block of ice,remove the rear panel inside the freezer and check the evaporator coil for this type of ice buildup,they should only have a light frosty coating on them when the units cooling and not defrosting,then either the heating element below the coil is bad,the defrost thermostat on top of the coil is bad or the defrost system isn't getting power to operate
Nov 14, 2010 | LG Refrigerators
Compressor is running all the time but temp does not come down. refridg is only cool,freezer is cold but ice machine also stopped working and a glass of water taked a few days to...
You may notice frost on the panel that covers the evaporator coil in the freezer. This is a tell tale sign of the coil being frozen up blocking air flow.
Inside the freezer compartment is where the evaporator coil is located. It is behind a cover that allows air to enter the bottom and then forced out the top by a small fan. You should be able to feel the air flow coming out the top. If no air flow the evaporator coil may be frozen and needs to be defrosted. There is a heater at the bottom of the coils which aids in this and may need to be replaced. A couple of screws usually holds the cover in place. Remove the cover and place a small fan in the door to aid in melting the ice. Do not apply heat of any kind ie hot water, blow dryer etc because this can over pressurize the coils and damage the system. The heater may look like a small light bulb. It can be checked with an ohm meter for continuity to see if it needs to be replaced.
Oct 06, 2010 | Maytag MSD2756GES Side by Side...
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Refrigerator isn't getting cold, but freezer part & ice maker seem to be working OK
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Refrigerators
Refridge is not cold freezer is fine
You have ice on the temp control door that has blocked air flow. You will need to pull off the back inside panel of the freezer and de-ice it or have a tech do it and test the defrost controller. That is most likely the reason for the freeze up in the first place. Hope this helps. Good luck.
Jul 07, 2009 | Refrigerators
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
FREezer works fine,frig will not go less than 40 degrees and unit never cuts off
the problem is the freezer drain is plugged up. when the fridge goes into defrost,the water that is suppose to drain out has no where to go. so it refreezes . that ice has plugged up the blend air vents between the freezer & the fridge.
1st put your food in a cooler. Unplug the refridge.
(you may want to take pictures as you go.for the reassembling)
open up the freezer, remove the rear panel, & the bottom panel (if possible)
you will see the coils, underneith the coils you will see an metal tray. it will probly have ice on it.
with a blow dryer, heat the ice till you see the drain . now that drain has to be cleaned out.
that drain runs down to the bottom of refridge into a drain pan. with a wet vac , attach it to the drain tube, until you fell suction in the freezer. small amounts of hot water does help.
( it usually gets plugged up from bugs)
next , open the fridge ,on the ceiling of the fridge.there will be a plastic cover (most models) remove the cover carefully. usually there are 2 passiges from the freezer to the fridge. that is where the cold air drops into the fridge. there will probally be ice in these passages, which has to be removed.(be careful with the stirofoam)
once you have cleaned out all the ice ,reinstall all those pieces.
plug back in the refridge.It will tak a day for it to get cold again.( hint get 2 bags of ice to help speed up the cooling down process)
Apr 27, 2009 | Refrigerators
Freezer is cold and collecting frost, refrig isn't cooling.
you may have to remove the floor of the freezer. At times they fill with water and freeze. and you cannot see the layer of ice under there. This ice can form in the channel that allows the cold air into the fridge. another suggestion would be to put the fridge on the lowest setting then raise it up about 3-4 hours apart. hope this helps. Good luck.
Apr 24, 2009 | Refrigerators
Fridg not cold
Ahhhh, the classic symptom of a frozen coil/air return duct. You'll have to pull the back panel off the freezer wall to view the coils. The are likely a block of ice causing the air channels on the sides to be frozen, thus blocking air flow. You may need a defrost t-stat or a defrost timer. If the defrost cycle isn't working then you will get a freeze up eventually. The only other reason is if the freezer door was left open slightly overnight letting in moist air. Let us know what you find.
Dec 27, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
