Question about 2wire (1000-400108-001) Router
Enable UPnP on 2 Wire ATT router
Enable UPnP
s4u311
  • 813 Answers
SOURCE: BEFSR81 admin problem when enabled uPNP
in the router has one rest pin just press it for 3 min then after try to logged in but remind u have to configer agin
defolt ip is 192.168.1.1
user: admin
pass:admin
try it
Posted on Feb 26, 2008
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
Posted on May 07, 2009
SOURCE: How to Enable UPnP on the router
it should be in your routers settings
192.168.0.1 D'link
192.168.1.1 Linksys ect.
Posted on May 31, 2009
sys_admin
  • 829 Answers
SOURCE: how do i enable UPnP on my router
For the UPnP architecture to work in Windows XP, the Internet gateway device must appear in Network Connections. To make sure that the device appears in Network Connections, click Start, click Run, type ncpa.cpl, and then click OK. Look for the Internet Gateway device:
Also, the router must appear in My Network Places. To make sure the router appears, click My Network Places in the Network Connections navigation pane, and then look for the router:
Collapse this imageExpand this image941206b.jpg Note The name that appears is the model name of the router. For information about how to enable UPnP on a router, view the router product documentation. If these devices do not appear, make sure that the correct components and services are installed in Windows XP. To make sure that the correct components and services are there so that you can enable UPnP, follow these steps:
  1. Click Start, click Run, type appwiz.cpl, and then click OK.
  2. Click Add/Remove Windows Components.
  3. In the Components window, click Networking Services, and then click Details.
  4. Click to select the Internet Gateway Device and UPnP User Interface check boxes in the Subcomponents of Networking Services window, if they are not selected.
  5. Follow the instructions that appear on the screen to complete the installation. Or, if you did not make any changes, close the Add or Remove Programs windows and Control Panel.
  6. Start the Services MMC snap-in. To do this, click Start, click Run, type services.msc, and then click OK.
  7. Locate SSDP Discovery Service in the list of services.
  8. If the status is not Started, double-click SSDP Discovery Service to open the SSDP Discovery Service Properties dialog box.
  9. In the Startup type box, click Automatic, and then click Start under Service status. Then, close the SSDP Discovery Services Properties dialog box.
Posted on Jan 16, 2010
I have a dlink 615 and need to disable the UPnP. How do I do that. I cannot get access to the internet because of a security problem with it
in most Routers
Steps to be followed for enable or disable the UPnP:
1. Open a browser and type in http://www.routerlogin.com/ or http://192.168.1.1 or http://192.168.0.1
2. Log in to the router. By default, user name is "admin" and the Password is "password". May differ in your device /settings
3. Click on Advanced.
4. Click on Advanced Setup and then click UPnP.
5. Click the Turn UPnP On box to enable or disable UPnP.
Sep 27, 2016 | Computers & Internet
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
Jun 29, 2015 | Belkin Computers & Internet
Need to open NAT for Xbox 360. Router is a Belkin DIR-628 and has already been port forwarded...
In order to open NAT settings for the xbox 360 you will need to enable Universal Plug N Play [UPnP]
To enable this setting in the Belkin DIR-628:
1. Log into the router
2. Click on the "Advanced" Menu on top
3. Click on the Enable UPnP: Checkbox
4. Click on the Save Settings Button
May 01, 2011 | Computers & Internet
How do I enable UPnP on a router
Login to the router throught your chosen web browser, then on the administration tab at the top tick the box that enables UPnP
"UPnP. If you want to use UPnP, keep the default setting, Enabled. Otherwise, select Disabled.
Allow Users to Configure. Keep the default setting, Enabled, if you want to be able to make manual changes to
the Router while using the UPnP feature. Otherwise, select Disabled."
Jul 03, 2009 | Microsoft Xbox 360 Pro System Console
Hay me again
to enable your upnp you need to "log into your router" the all your settings will be there for you to change such as enable upnp tutorials for this can be found on youtube
Jan 27, 2009 | Sony Playstation 3 (PS3) Console
Wii wifi connection
Try to uncheck UPnP Enable on your router located on advaced network setting. or try reconfiguring your wireless network settings.
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
UPnP?
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-714P+, DI-754, DI-764, DI-774, DI-784, DI-804HV, and DI-808HV. Universal Plug and Play (UPnP) allows discovery of UPnP enabled devices in a network environment. UPnP is only available on Windows Me and XP. If you are not using either operating system on any of your computers, or do not want to use UPnP, then it is recommended to disable UPnP on the router. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Tools tab then click Misc. to the left. Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wireless router, or select Disabled using the radio buttons to disable it. Step 5 Click Apply and then click Continue to save the new settings.
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
How do I configure UPnP? on my router?
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
2wire (1000-400108-001) Router Logo
2,792 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
