Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Inop dishwasher will not operate. wash lite is illuminated
    Genius:
  • 1,075 Answers
I would say the door switch needs replaced.adrian,,,
Posted on Jul 20, 2010
What is the fuse number for the dashboard lights on a 2007 Ford Focus 3 door hatchback?
Principles of Operation
The instrument cluster and panel illumination consists of dimmable and non-dimmable illumination components. The dimmable illumination is controlled by the instrument panel dimmer switch, which allows the brightness level of the backlights to be adjusted to the customer preferences. With the parking lamps ON, the instrument panel dimmer switch uses electronic circuitry to provide a variable pulse width modulated (PWM) output to the instrument panel and all applicable switches depending on the driver-controlled level of intensity. The headlamp switch backlighting consists of 2 constantly illuminated LED bulbs that are powered by separate circuits. Battery voltage is supplied to the first bulb when the ignition switch is in the RUN position. Battery voltage is supplied to the second bulb with the parking lamps ON. The non-dimmable illumination allows for full intensity dependant on the ignition switch position.
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Instrument panel dimmer switch
  • Circuitry
  • Connector(s)
  • Headlamp switch
  • Illumination source(s)
  1. If an obvious cause for an observed or reported concern is found, correct he cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, verify the symptom and GO to Symptom Chart .
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The control illumination is inoperative
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test A .
  • The instrument cluster illumination is inoperative
  • Circuitry
  • Instrument cluster
  • Go To Pinpoint Test B .
  • The climate control panel illumination is inoperative
  • Circuitry
  • Climate control panel
  • Go To Pinpoint Test C .
  • The audio unit illumination is inoperative
  • Circuitry
  • Audio unit
  • Go To Pinpoint Test D .
  • The transmission control lever illumination is inoperative
  • Circuitry
  • Transmission control lever illumination bulb
  • Go To Pinpoint Test E .
  • The hazard warning switch illumination is inoperative
  • Circuitry
  • Hazard warning switch
  • Go To Pinpoint Test F .
  • The traction control switch illumination is inoperative
  • Circuitry
  • Traction control switch
  • Go To Pinpoint Test G .
  • The window control switch illumination is inoperative
  • Circuitry
  • Window control switch
  • VERIFY the operation of the window control switch in question. If the window control switch is inoperative, REFER to Section 501-11 . If the window control switch operates correctly, INSTALL the new window control switch in question. REFER to Section 501-11 .
  • The instrument panel illumination does not dim
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test H .
Pinpoint Test B: The Instrument Cluster Illumination Is Inoperative
Normal Operation A variable pulse width modulated (PWM) voltage is supplied to the instrument cluster through circuit 29S-LA31 (OG/BU). The instrument cluster is grounded through circuit 91-GG14 (BK/OG).
    Possible Causes
  • circuit 29S-LA31 (OG/BU) open
  • circuit 91-GG14 (BK/OG) open
  • instrument cluster
PINPOINT TEST B: THE INSTRUMENT CLUSTER ILLUMINATION IS INOPERATIVE CAUTION: Use the correct probe adaptor(s) when making measurements. Failure to use the correct probe adaptor(s) may damage the connector.
Sep 24, 2017 | Ford Cars & Trucks
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Water does not come into the dishwasher. can hear the pump, the heater works, the indicator lites illuminate, but water does not come in. The water supply is hooked up and turned on, there is good flow...
Usually the problem is the soleniod valve that lets the water into the dishwasher...
here is a tip that I wrote that gives many more details about this problem...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 21, 2010 | Dishwashers
Won't start
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 24, 2009 | GE GLD5900NWW / GLD5900NBB / GLD5900NCC...
Mdb9100 totaly dead, does nothing, worked normally last load, circut breaker has been checked
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 04, 2009 | Maytag Dishwashers
Mdb9100 totaly dead, does nothing, workrd normally last load, cirtcut breaker has been checked
Hi
Thanks
Rylee
Will not start
Hi
Thanks
Rylee
Nov 27, 2009 | Kenmore Dishwashers
My KitchenAid dishwasher quit workin no light no nothin, float switch is good, having problem troubleshooting water fill valve with solenoid???
Hi
Thanks
Rylee
Nov 18, 2009 | KitchenAid Dishwashers
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
80 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
