Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I replaced a bad HV Control Board but the unit's code won't work
I just replaced a bad HV Control Board (PN12920724) on my Maytag MFI2067AEB refrigerator, but it will not accept the program code from the ID plate. The display panel keeps flashing "PE0000" after I repeatedly follow the programming steps. The unit itself works again (freezer, ice, water, etc.), but I can't use the panel due to the flashing PE0000. Any advice would be greatly appreciated. Thanks.
John
SOURCE: programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Posted on Oct 26, 2008
YukonJack
SOURCE: FRONT DISPLAY SHOWS (PE0-000)
When the hv board is replaced, the display must be re-programmed using the code inside the upper compartment on the right side.
Posted on Jun 04, 2007
SOURCE: Maytag MF12568AEW (white) Problem
For temporary relief of problem, disconnect power to front panel. The connector is located under the left door hinge cover on top left of refrigerator. Unscrew cover to remove.
Call Maytag, 1-800-688-9900, try to get the automated system to connect you to a real person (try saying "representative"). Explain to rep that you are aware this is a common problem with the HV Control Board - Part number: 1206507. Maytag is aware of this issue and said to me that this is an "improved" part. For me, they shipped the part out Fed Ex and set up a time for a serviceman to come out and fix it - all at no charge. I didn't want the hassle of waiting around for a repairman so I replaced it myself. It's pretty easy. The part came with instructions for programming. Here's the steps to replace if you want to do it yourself. *** I'm not a professional. Do this at your own risk. ***
Repair:
1. Pull the fridge from the wall and unplug it.
2. Wait 15-20 minutes
3. Remove the screws securing the HV circuit board cover on the left rear side of the fridge. (left as if you were facing the rear of the fridge)
4. Remove the clear plastic cover.
5. Verify that the fridge is unplugged.
6. Remove the 4 wiring harnesses from the circuit board. Using your finger press down on the locking tab while gently pulling the wire harness out.
7. Once all the wires are free, remove the circuit board by pressing back the plastic retaining tabs while gently pulling the board out.
8. Insert the new board oriented the same way as the old. The board will snap into place.
9. Reconnect all 4 wiring harnesses.
10. Replace the clear plastic cover
11. Replace the steel cover and secure with the 4 screws.
12. Program the new circuit board according to the included instructions. Programming requires that you enter a specific number listed on the inside of your fridge into the front panel, this in turn programs the board. Without this step, the fridge will not work. It's the number after CODE on the tag that includes model/serial number
Programming Mode:
1.Press and hold the Door Alarm Keypad.
2.Press and hold Freezer Temperature Down Keypad.
3.Release the Door Alarm Keypad and wait 3 seconds.
4.The control will display PE to indicate the programming mode.
5.Entry is confirmed by pressing the Freezer Temperature Down Keypad - once more.
6.The control will display the current Program CODE.The value should be validated with the Program CODE printed on the unit serial plate.
7.Press the Refrig Temp Up Keypad or Refrig Temp down Keypad to change the digit value with each key press.
8.The decimal point indicates the selected digit. Press the Freezer Temp Up keypad to select the next digit.
9.Once the desired Program CODE is displayed, press and hold the Freezer Temp DOWN keypad until the Program CODE begins flashing indicating it has been saved.
Posted on Apr 28, 2008
  • 220 Answers
SOURCE: I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
Posted on Sep 01, 2009
  • 16 Answers
SOURCE: Ice maker not making ice
check the water solenoid for the ice maker on the back
Posted on Jun 11, 2010
We woke up this morning with the lights flashing and the ice maker shoot door clicking every 6 seconds and it won't stop. Any ideas how to reset it or get it to stop?
Your High Voltage control board has gone bad there are capacitors on the board that are bad and you can try to replace them or buy a new HV board.
May 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Aug 31, 2009 | Maytag MFI2568AE Side by Side French Door...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
I have a Maytag model no: MFI2568AEB I replaced the HV Control board in the back, when plugged in the front panel now reads PEO OOO and the you cannot put your code in O3O2 all freezes, please help. Thank...
i would unplug and start again,refer may be board.as you seem to know with out that code in there it wont work[been there done that]and you have to read carefully and do just as instructions say to pull it off.you can do it though. God bless ,tom
Jan 24, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
What is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Jul 30, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Feb 05, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
204 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
