Can't find phone jack for faxes on copy machine on mf 6500 series
  • seamus48 Sep 28, 2008
    I have an HP Laser jet 6L and I need a driver to run with Vista on a laptop for IEEE to USB cable, is there one out there?
    Jim
    Scholar:
  • 67 Answers
Hi. I guess it's already sitting in place. The phone jacks are usually in the back in a place only a design engineer would pick. I am not trying to be anything but helpfull, but I'm not kidding. You have to move the copier away from everything else where you can really look.
Or you bought a model without that feature, probably without being told about that.
That is really frustrating, I'm going fishing, or "casting" as my distractors say. Good luck.
Posted on Apr 21, 2008
How do I install connect fax and scanner to my computer
There are a minimum of 3 cords:
power
phone
computer (likely USB)
Power to the wall.
Phone to a phone line.
USB cable to the computer.
Computer should recognize the machine is there. Load software.
Sep 11, 2014 | Copystar REFURB HP Office jet 6500...
When recived fax it half the size of A4 paper.but when i send fax ok.
If you are able to make copies ok, I mean you get a full page of the copy, but when receiving a fax you're getting only half a page that could be a problem with the line. First, let's make sure you have all the settings right. Make sure that you have the phone cable plugged in to the port where it says line at the back of the fax machine with the other end going directly to the wall jack. (If that is a digital phone line that you have, the more that you'll have difficulty in receiving faxes, because fax machines are designed to work on analog phone lines only) Also, try turning Off your Error Correction Mode (could be found either on Basic or Advanced fax settings) If you have an answering machine on the same line with the fax, set it to 2 rings lower than the fax machine's number of rings, that way when a call comes in, the answering machine picks it up first, if a fax tone is heard, fax machine picks up. It is not recommended if you have a voicemail on the same line with the fax, if you do, it's either request to turn it off from the phone company or request for a distinctive ring, then set the distinctive ring by accessing your Advanced fax settings.
If you have all those notes above set, and you're still not being able to receive your faxes, let's check on your line. Try to plug the fax machine to a different wall jack and have someone send you a fax, if you receive the fax, then the wall jack where your fax was previously plugged in to must be faulty. Call your phone service provider for the issue.
If you're still having the same issue with the fax, with it plugged in on a diff wall jack, call the customer care hotline for your product.
Apr 26, 2011 | Office Equipment & Supplies
How do i use lexmark 6500 fax machine with majic jack
It won't work. Fax machines are analog, magic-jack is digital.
Feb 15, 2010 | Lexmark Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
I have a MCF LC-51 series fax, and scanner I cannot fax or recieve.
check for a dial tone using a regular phone plugged into the wall jack.
make sure the phone cord is hooked into the LINE jack on the machine
make you do NOT have a DSL line.
Sep 02, 2008 | Brother Office Equipment & Supplies
Sending and receiving faxes
Make sure the phone line is plugged into the LINE port of the fax machine. Plug a regular phone into the phone wall jack and listen for the dial tone.
Sep 01, 2008 | Office Equipment & Supplies
I can recieve or send faxes!
The phone jack is missed up after all
Jul 23, 2008 | Brother MFC-8220 Fax
My Magic 5 Fax/phone machine is no longer recognising the cordless phone that came with it and while I can get the cordless handset into registration mode, the device (base station) will not register it...
See if your cordless phone will work when plugged directly into the wall jack.If it does then plug a regular phone into the faxes phone connector, EXT jack. See if you can make a call. If you can plug the cordless in again to the EXT jack on the fax machine. In order for the fax switch to function, the machine must
be first in the series if multiple devices are connected to the
same telephone socket. Follow the correct order
If you have multiple telephone sockets for the same
telephone line, the machine must be connected to
the first telephone socket.
If you still get the error I recommend a servicecall to the manufractorer
Jun 16, 2008 | Philips Office Equipment & Supplies
Canon mf 6580 is clicking
Ususally the clicking happens when a live phone line (from the wall jack) is plugged into the extension jack on the machine. The extension jack will have a little icon of a telephone next to it. The line from the wall should be plugged into the jack with an "L" (Line) next to it.
Apr 28, 2008 | Canon imageCLASS MF6580 All-In-One Laser...
51 people viewed this question
k24674
jasbo
jasbo
