Question about Dell Latitude D630c Intel Core 2 Duo T7500 4M L2 Cache, 800MHz FSB 80GB/512MB PC Notebook
Dell latitude D630C starts up with blank screen.I cannot connect to external monitor(blank also) was working for a while then just shut of formatted the hard drive but cannot install windows 7. 320 GB Hard Drive 4 GB memory THANKS
    Guru:
  • Dell Master
  • 468 Answers
Hi Starkey, Thank you for contacting Fixya. This is Anil. I understand that you are unable ti install Windows7. don't worry I will glad to help you with it. Starkey, I advise you unplug all the cables from computer, uplug the battrey and power cable also. Keep on holding the power button for 20 secs, it will drain the static power. Now turn on the computer and insert Windows7 CD. We will try a clean install. Please follow the steps mentioned below Step-by-step Windows7 installation What is a clean install? The TuneUp Blog described an upgrade installation in the last post. The alternative to that is a clean install of Windows 7, in which you essentially wipe your hard disk clean and start from scratch. As discussed in an earlier blog post, upgrading old Windows Vista systems is easy?but not the ideal process for end-users. Although you might save a couple of hours by taking the upgrade route, system performance can take a severe hit. If you?re using Windows XP, the clean install is your only option; an upgrade to Windows 7 is not allowed. The Windows 7 setup screen Preparing for Windows 7 The first step is to check if your computer is capable of running Windows 7 (We recommend that you read about the Windows 7 Upgrade Advisor). If the Upgrade Advisor mentions a possible incompatibility, check the hardware or software manufacturer?s Web site, and see if there?s an updated driver or program patch that ensures Windows 7 compatibility. Don?t worry?nearly all of the hardware and software that works with Windows Vista will work with Windows 7, since the underlying architecture has not changed significantly. In preparation for Windows 7, make sure you have the following ready: An external hard disk or a second partition. It is important that you save photos, music, documents, and any other important files to this drive. Use the export function of your e-mail client and your Internet browser to save your e-mails and favorites, respectively. Also, be sure to check the ?C:\Program Files? directory for any important folders you might want to keep. All of your important programs in installable form. Go to the ?Programs? category on the Windows Control Panel, and check that you have all of the important programs listed there or saved on a DVD or as an installer file. An image of your entire computer. In case something should go wrong, it is always advisable to have a complete backup of your system. One recommended tool for images is Macrium Reflect, and best of all?it?s free! Save your images to a DVD or external hard disk, as well. The clean installation process Start your computer and insert the Windows 7 disc. When the message ?Press any key to boot from CD or DVD?? appears, hit a key, and read step 2. If this does not happen, you need to enter your computer?s BIOS and make sure that your PC boots up from your DVD drive. To access the BIOS, press F2 or DEL (or see the manual or on-screen text for other instructions). Once you?re there, try to find the boot priority order; for example, on one of our test machines the menu is just called ?Boot?. Go to ?Boot Device Priority? (or something similar), and select the CD or DVD drive. Save these settings, and start the setup! Changing the PC?s boot priority After a couple of moments, the Windows 7 setup will start. Click ?Next?, and then ?Install now?. Select ?I accept the license terms?, and click on ?Next?. To perform the clean installation, select ?Custom (advanced)?. Select your main system drive (usually Disk 0 Partition 1), and click ?Format?. This will delete all of your data and the previous Windows version. Formatting the hard disk Click ?OK? and ?Next? to start the installation. This process usually takes about 15 to 30 minutes, depending on the performance of your computer. After the setup, enter your user name and computer name. (This is the name that will appear for other PCs on the same network.) In the next step, enter your password. Setting up a password for the user account At the end of the process, simply type in your Windows product key, and click ?Next?. Then make sure that Windows automatically downloads updates. To do that, click ?Use recommended settings?; then click on ?Next? to confirm the time and date settings, if they are correct. In the next step of the assistant, select the network security settings. If you select ?Home network? or ?Work network?, you will be able to see other computers, and they will be able to see your PC as well. If you?re on the go, hit ?Public network?. Choosing the correct network security setting The Windows 7 desktop right after installation After a couple of moments, you will see your clean Windows 7 desktop. The first thing you need to do is go online and check for Windows Updates. Simply click on the start button, and select ?All Programs?. Click ?Windows Update?, and hit ?Check for updates?. After you?ve selected ?Install updates?, Windows 7 will automatically download and install all of the necessary drivers and Windows Updates. Downloading and installing essential Windows updates Now it is time for you to reinstall all of the important programs you need and copy your data back on to the computer. I believe the above resolution should resolve the issue, however, if you need anymore assistance, please feel free to contact us. We will be glad to help you. Thank you. Have a Great Day. Regards, Anil.B.R
Posted on Jul 20, 2010
  • starkey580 Jul 20, 2010
    Hi Anil
    Thanks for replying so quickly. Computer works perfectly... screen does not even when connected to external monitor.Checked screen connection thats fine.
    It worked for a few weeks then on and off then totally stopped.
    thanks again
Dell laptop latitude e4300 - screen goes blank after starting Windows
Windows files are corupt or the hard drive has issues, try and reload operational system if disc is available, have the hardware checked if unable to load.
Oct 26, 2012 | Dell Latitude D630 Notebook
D630 screen is black once it starts up it illuminates but stays black
You must detect what parts is failure
Screen display, inverter board or lamp
Follow these step.
1.- Connect an external monitor (at VGA port) and check the image in external monitor
If show clear image. The failure may be the inverter board or the lamp backlight
Inverter boars is more easy to replace.
You can buy an used cheap price on
http://www.ebay.com/itm/Dell-Latitude-D630-Inverter-Board-K021048-00-/260809995144?pt=LH_DefaultDomain_0&hash=item3cb97cb388
Replace and your screen will work again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Dell Latitude D630 PC Notebook
Latitude E5400 screen flickers when external screen connected, extrenal screen OK
Please try to:
check the highest resolution of the external screen then set the resolution of your laptop base on the capacity of the external screen right click on the blank section of your screen then click properties then go to settings choose one like 1024 x 768 press ok plug the external monitor make sure the cable is in proper position then power on the monitor enjoy
thanks for using Fixya
May 31, 2011 | Dell Latitude C400 Notebook
Dell Latitude D630 Problem With The Screen has a D630 with nvidia nvs135 and it dont show nothing on the screen, i tried to connect it to a lcd monitor none works. The displays are working, but its just a...
If you don't get a display on the external monitor, then most likely your video circuit is the problem. If your laptop has a plug-in video card it can be replaced. However if it's integrated into the motherboard then you'll have to have that replaced.
Jan 26, 2011 | Dell Latitude D630 Notebook
The bottom 1/3 of the screen is blanked out although the machine is totally usable I can't see anything below the blank screen. It will then clear and I can work normally and then the same portion of the...
Hi friend, In this case I would recommend you to connect any external monitor to the laptop and check if you have the same issue on the external monitor as well. If the same issue occurs on the external one than we can try installing the latest video drivers for the same'
If the external is fine, then i would recommend you to please change the LCD of the laptop
Dec 08, 2010 | Dell Latitude D520 - Celeron Intel Celeron...
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Jan 19, 2010 | Dell Latitude D430 Notebook
System won't start up.
OK, your system appears to be posting but you have a NO VIDEO issue. Most likely the issue is a backlight failure of the LCD screen. If available, you can connect an external monitor to the VGA port and press FN+F8 to toggle between the LCD and the External screen (Wait 15 seconds between toggles)
The components are fairly easy to replace and available on Ebay.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=latitude+d810+LCD&_sacat=See-All-Categories
Nov 21, 2009 | Dell Latitude D810 Notebook
External montior is blank
Are you sure the laptop is powering up?
Do you hear the laptop boot up and the hard drive spinning and the power LED is on when you connected the external monitor?
The monitor must be powered up before the laptop for the video info to switch video port automatically.
If the external monitor is blank then you can't make it work, your video card is faulty and it is not possible to replace as it is built-in on the motherboard. You could replace the motherboard but this may not be a cost effective solution,
May 05, 2009 | Dell Latitude D610 Laptop Computer -...
External display not displaying!
When you are able to view a video clip on the external monitor, We can rule out the issue with the software. Probably you need to check the connections and also the external monitor settings in the display. The reload might have changed the old setup
Feb 03, 2009 | Dell Latitude D820 Notebook
Display not working properly
You should be able to plug in an external (Desktop type) monitor . Look for a connector on the side or back of the laptop. If the external monitor works, you have pretty much diagnosed that you have a LCD problem.
Ron-
Mar 07, 2008 | Dell Latitude D600 Notebook
Dell Latitude D630c Intel Core 2 Duo T7500 4M L2 Cache, 800MHz FSB 80GB/512MB PC Notebook Logo
124 people viewed this question
Alun Cox
