Question about Sharp R-1214 Microwave Oven
Sharp r1214f sparking New issue sparks with microwave popcorn, butter and microwavable ice cream.
    Sergeant:
  • 298 Answers
The container of these items probably contain some metal which doesnt go with the microwave
Posted on Jul 19, 2010
  • pbs_mark Nov 28, 2013
    Thanks. It wasn't metal in the container. It turns out certain butters will behave like this.
My microwave sparks when making popcorn
if bag has any part of it that is tin foil it will spark
Feb 15, 2015 | GE Spacemaker JVM1640SJ Microwave Oven
Change spark
Check diode and capacitor. Instructions should be found inside the unit.
Nov 11, 2017 | GE Advantium SCA2001BSS Microwave Oven
Microwave sparking
The magnetron is arcing, or bare metal is exposed on the inside of the microwave oven, I recommend having it checked before further use.
Aug 13, 2012 | Jenn-Air Microwave Ovens
Sharp R305KS Stainless Steel 1100 Watts Microwave Oven problems:1.5 years old. We put in a microwave popcorn bag and had bright flashes going off as though there was metal left in there and gurgling...it...
unplug microwave.
Take ALL dishes out of the microwave and do a proper check of the inside the cooking area. If you are sure that's ok put the glass dish back in if it has one.
Test that the oven and grill are still functional.?
Do they heat up? If they do then get one of those microwaveable bowls or dishes and put some water into it. Place it back into the microwave and do the check again on microwave heating.
Does it bang or spark again?
If it does and the other heating is OK then the Magnatron to me sounds as it's on it's last legs.
That does not mean you have to scrap the microwave if it is the Magnatron. as a new one can be purchased and installed.
Apr 12, 2017 | Sharp R305KS Microwave Oven
Microwave sparks and makes noise only when fixing microwave popcorn. Otherwise, microwave works fine. The microwave previously worked fine with microwave popcorn. This happened with another brand of...
Hello bruton. As a microwave oven ages, the interior paint often deteriorates as does the internal part that creates the micro waves.
Using this is not a good idea as there is now a fire hazard. The best solution is to replace the microwave. There are sales now and you can get a nice new one for under $100.
Joe
Thanks for choosing Fixya!
Mar 23, 2011 | Microwave Ovens
My sharp r-510hw flashing like crazy
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 22, 2008 | Sharp R-510HW Microwave Oven
Microwave oven by ultrex
The sparking is usually due to accumulated grease or food particles.
If there is any chipping, charring or rust, it will have to be sanded smooth and clean.
Sparking is most likely to occur when cooking small items or low-moisture foods like popcorn.
I always recommend that folks put food off-center on the turntable to assure more even heating and to protect the turntable glass.
Mar 09, 2008 | Microwave Ovens
Heat's water great , won't pop corn
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
Dec 02, 2007 | Sharp R-820B Convection/Microwave Oven
Sparking/growling NEW microwave
Don't use it! Unplug it and take it back to the dealer-sounds like a loose wire or short.
Jun 24, 2007 | Westpoint TV-201 Microwave Oven
Sharp R-1214 Microwave Oven Logo
284 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
