Question about MicroBoards Primera Signature IV InkJet Printer
When printing using DiscJuggler, my Sig IV printer prints a disc, the tray comes out, but immediately retracts and makes a nasty racket until the power is disconnected. When power is reconnected, the disc tray will come out when the manual switch is pressed, and at that point, the robot takes over again: it picks up the printed disc, deposits it on the "done" spindle, and loads a blank disc. When that disc is printed, it instantly retracts and makes the noise.
  • 3,083 Answers
The racket you're hearing is a problem with the gears that drive the tray. The unit will have to be disassembled to ascertain what the problem is. Most likely you will have a bad gear, or there will be some problem with a sensor/control board. Bottom line is that the unit will need servicing, which will require opening it up and inspecting/troubleshooting it. Primera warranties this unit for life, but one must still pay for repairs after 1 year (which puzzles me, and sounds like some kind of a contradiction). They do have reportedly excellent free phone support, indefinitely, however, so your first recourse would be to contact them, and go from there. Here is Primera's contact site, and their support phone number:
http://www.primera.com/contact_tech_support.cfm
Scroll down the page for their phone number.
Good luck, and hope this helps.
Posted on Jul 20, 2010
  • abradley2000 Jul 20, 2010
    Thanks for your help. I do think it's a sensor/board issue, because it is possible to open and close the tray manually (and print discs one at a time). Just a note, in case it prompts an additional idea: This unit was recently moved and setup again. Prior to moving, the unit printed 400 discs w/o a problem.
    Thanks,
    Alan
Red LED keeps flashing
Hi
I've been stuck with a flashing red paper light for a while. The printer could print from the manual tray and could also print test or diagnostic pages.
So I thought it might be driver related, and indeed it was.
There's a nasty setting in the printer properties that makes the printer go woo-hoo. So go to printer properties > tray settings. Check the "paper size" of "Tray 1". If it's set to "undefined", change it to your corresponding paper format. Click Update, Apply. Now print happily.
I still wonder why that setting magically changed. Hope this helps someone.
techbelkin
Dec 28, 2010 | Brother HL-2070N Laser Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Epson R265 the disc print tray keeps jamming
did you align the track? check the tray for any cracks, when you try to print cd's make sure that the printer and cd are balanced in a horizontal or even manner
Sep 12, 2009 | Epson Stylus R265 InkJet Photo Printer
Similar pick up and drop problem
Try reinstalling the drivers. Does the printer tray retract?
Jul 13, 2009 | Primera Technology Primera BravoPro...
How to change the default tray on a HP 2430?
print config page of printer,see how trays are configured.
Jul 01, 2009 | HP LaserJet 2430n Printer
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Out of paper light
Aug 29, 2006 | Brother HL-2040 Laser Printer
MicroBoards Primera Signature IV InkJet Printer Logo
29 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
Don  Farrell
Don Farrell
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
