Question about RCA Televison & Video
I have a RCA VR704HF. I am unable to play VHS tapes;. As soon as I put in a tape I get an ERROR message and the VCR player turns off.
  • 979 Answers
Hello sir, Hi, there are lots of possible causes for this, one could be the loading mechanism, the tape does not load properly, this needs cleaning, and its mechanical, so it needs some oiling, The main board needs checking for shorts and leaking capacitors, Especially the power supply board. Have a voltage check for the power supply voltage. the regulator may need to be checked.
Posted on Jul 20, 2010
No sound when playing a tape in the rca vcr player
If it's connected with a scart cable, then there may be a bent pin or broken wire.
Jul 06, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
Tape end camcorder
Have you tried different VHS tapes? If your VHS tape is too far rewound or at the very end your camcorder will display this problem. In a different VHS machine make sur the tape is rewound and then play the tape about a minute and then try it in the VCR.
If this doesn't work then there is a problem with the tape end sensors in your VCR.
Oct 04, 2008 | Video Cameras
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
RCA VR688HF VHS VCR won't accept tapes
The brain in a VCR has a little switch assembly that senses what position all the mechanical stuff its in. Apparently, the mech is out of whack which is why it won't let you play. This is a common problem and any VCR shop should be able to repair it.
Dec 22, 2007 | RCA VR622HF VHS VCR
Backup my vhs tapes
First hook up the VR357 to the TV with any cable ..
Then put a VCR tape into the VHS player.. get the tape to where you want to start the recording and press stop.
Then put a blank DVD in (-r or -rw is the best)
Then press VCR on the remote
Then press TO DVD on remote
you will see the word COPY come up on the DVD player and the VHS tape will start to play.
When you are done just press stop twice. and you will get a message that says "updating information to disk"
Dec 15, 2007 | Samsung DVD-VR357
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
