Question about Microwave Ovens
One ignitor started clicking and won't stop until I cut off the circuit breaker. My electric oven does not work. They are GE and are built into countertop.
  • 821 Answers
Hello,Check the wiring harness from control to heating element, it may be having a contact with chassis (ground) somewhere.
Today's ovens come in two basic types: electric or gas. An electric oven uses large coiled wires inside that heat up in order to cook the food. There are two sets of these coils, one on the top and one on the bottom. These heating element heat up when electricity is sent to them. The bottom coil of wires is the one that cooks the food when you bake.
The dial on the oven controls an internal thermostat. When you turn it to set the temperature, a copper wire that leads to the cooking area is alerted to the temperature that you want. This wire serves as the temperature gauge, and it sends signals to the thermostat to turn on and off based on the temperature inside the oven. The top heating coil is the broiler. This coil will heat to high temperatures very quickly. It does not have a temperature control like the coil on the bottom. It will heat to its highest possible temperature and stay there until you turn it off.
wish you good luck,
take care.
Posted on Jul 19, 2010
Model 8006262000
I assume your oven is electric and not gas? If so, consider replacing the fuses on the oven, which are located in the back. THese fuses are pretty cheap, just ask around at the hardware store. This should fix your problem.
Dec 05, 2013 | General Electric GE 27"" Built-In Double...
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL DISPLAYS ARE ALL BLACK, CIRCUIT BREAKER NOT TRIPPED. The oven was actually working, then suddenly in the middle of warming the food, it did quit -...
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Nov 09, 2009 | GE JVM1190 Microwave Oven
Micro stopped working
Try looking at the microswitches behind the door.
Apr 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
