Question about Frigidaire FAC127S1A Air Conditioner
Frididaire Window A/C FAC127s1a - 1 year old unit working until I cleaned the filter. Now it doesn't blow cold, just the fan blows. About a week before that, the unit started leaking in the inside the house. Never had a problem with leaking before. Could this be related?
RepairUSA
  • 50 Answers
SOURCE: Window AC takes spells on cooling?
One thing to check is to make sure the evaporator and condenser coils are clean. Any dirt here will short ccle the compressor.
Posted on Aug 25, 2007
SOURCE: No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Posted on Jun 29, 2008
  • 11 Answers
SOURCE: Frigidaire FAH106N1 Thru-Wall/Window Air Conditioner
Check for blockage of the air pathway. Check that the fan turns freely, as the bearings or bushings could be shot. The fan blades could also be loose. You might just want to replace the fan, as it is cheaper than replacing bushing/bearings.
Posted on Jul 08, 2008
  • 659 Answers
SOURCE: Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Posted on Apr 11, 2009
projdoc
  • 2237 Answers
SOURCE: A/C UNIT FANS BLOWS NO COLD AIR COMPRESSOR KICKS ON THEN OFF
check fins in the condenser coils (the fins on the outside part) for obstructions or alot of bent fins. should be free and clear. but chances are the freon level is low. can be serviced, but may be cheaper to replace.
Posted on Jul 20, 2009
FAC127S1A Air Conditioner - FAN blows, but compressor will not come on. Control board works properly. Suggestions please? 903 918 3418
Likely not coming on due to a safety. Likely tripped on low pressure. I believe this a window unit, many times repairs outweigh replacement.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 03, 2017 | Heating & Cooling
I have a Fedders Window Air conditioner, model A2008F2BG. It was working great until today. Now it comes on but the fan wont blow much air. Any ideas?
I believe that is an older window unit. I don't know how difficult it is to get to the fan, but I would check to see if it can be cleaned, then see if there is any insulation or anything that is blocking air flow. I am assuming the filter is clean?
Aug 01, 2016 | Fedders Heating & Cooling
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
I have a Rheem 10 series ac that is only 11 years old. The coils are clean inside and when i opened up the unit outside and ran water over the compressor and frosted lines, the unit appeared clear of any...
TO LO OR HIGH!!! ALSO THE FILTERS COULD BE DIRTY OR AN AIR RESTRICTION IN YOUR RETURN AIR DUCTWORK OR DUCT IS NOT BIG ENOUGH.{ NOT ENOUHG AIR BLOWING ACROSS THE INDOOR COIL} IF THE UNIT ISEQUIPPED WITH A TXV THIS COULD BE CLOGGED AND WILL HAVE TO BE REPLACED BY A CERTIFIED A/C TECHNICIAN. FIND A FRIEND WHO HAS A TRUSTED AND HONEST A/C GUY... GOOD LUCK
Oct 17, 2010 | Heating & Cooling
My wintair window unit stopped blowing. It turns on and cold air is slowly seeping out of it but it's not blowing like it used to. It's only 1 or 2 years old. Is this something I can easily fix?
Hi1!
You would need to check he blower motor capacitor and speeds. Try turning on just the fan to see if it blows faster and more air.than when the compressor is on.
Worst case scenario, your fan motor is failing and needs to be replaced
Good luck!! Rate this post!!!
Aug 14, 2010 | Heating & Cooling
How do i figure out why it's blowing cool but not cold
It sounds like the compressor is not coming on. It may be the thermostat. Take the metal wire with the fat end, make sure not to kink the wire, this is the sensing bulb Warm it in your hand. If you hear a click it works and you need a new window unit. They cost as much to get fixed as a new one. If the thermostat does not click then that is the problem.
Apr 19, 2010 | Fedders AEQ07FBG Air Conditioner
HAIER 1 YR. OLD A/C UNIT BLOWS ONLY WARM AIR
well it sounds like the compressor is not turning on. does it have thermostat? if so turn it way down. clean any filters. is it a window unite or portable most of them are too costly to repair unless you do it your self.
Jul 06, 2009 | Heating & Cooling
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
Apr 11, 2009 | Frigidaire FAC052K7 Air Conditioner
Frigidaire FAC127S1A Air Conditioner Logo
76 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
