Question about BenQ PE7700 Multimedia Projector
BenQ PE7700 projector starts ok and then fans stoping and red light starts flahing and everythin on screeen disapears manual said taht problem is fans not working i see then fans working when i start projector then after 10 sec they stop working and everything stops working can anybody help thank you
  • 1 more comment
  • joudd Apr 21, 2008
    i cant go to reset it because projector stops after 10 seconds working
    both red lights starts flashing and fans stopping
    when i start projector i see fans working
  • Anonymous Mar 19, 2014
    strange popping noise followed by large buzzing/alarm type sound
    popping sound followed by alarm/buzzing sound - no particular lights indicating the problem
  • 3,422 Answers
Check if the unit has a Filter Timer ? If it does have one - check the hours on it and reset it.
If the problem still occurs or there is no filter timer in the Menu - check that all your fans are running.
Hope this is of help
Please don't forget to rate the solution.
Posted on Apr 21, 2008
  • Priya darshan Apr 21, 2008
    try cleaning the filter and if you still face the problem then you will have to get it serviced or replace it if it still under warranty
Can I replace the fan and how do I do it for a Benq PE8700
If the lamp LED flashes red, it indicates that the front cover is not installed properly, the fan is not working, the translation board is defective or the ventilation holes are blocked.
The first thing I would try is to remove the lamp assembly and try reinstalling. (Did you purchase a genuine BenQ lamp assembly)?
If ok, you can download a service manual here (but be advised, this is not for the unqualified. You should seek repair through your dealer).
Elektrotanya for electronics experts
Jun 16, 2017 | BenQ PE8700 Multimedia Projector
My Benq projector is cutting off part of the screen image (the top and bottom)...I've tried adjusting the resolution on my computer, but nothing seems to work. Any suggestions?
when you say its cutting off the image, do you mean it is blanking the top and bottom off the picture. Is the image that is displayed on the computer the same as on the projector or is it just a cinemascope version of the computer screen
Mar 10, 2011 | BenQ PE7700 Multimedia Projector
My BenQ PE7700 stops working after a couple seconds.
the lamp is running too warm from inability to cool down. clean out the dust with canned air and check the fans. the temp sensor may need to be replaced, as the heat may have desroyed it.
Oct 14, 2009 | BenQ PE7700 Multimedia Projector
Benq pb8250 , red light blinking
you have a problem with either the fans, the ballast, or the colorwheel. if the fans turn on, listen for a high-pitched whir. if you don't hear it, replace the colorwheel. if you do, replace the ballast. if the fans don't spin, replace them.
Sep 22, 2009 | BenQ PB8250 Multimedia Projector
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
BenQ PE7700 Multimedia Projector Logo
628 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
