Question about Samsung RS2534 Side by Side Refrigerator
Freezer side working but refridge side not getting cold
  • Samsung Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorfreezer side working but refridge side not getting - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 19, 2010
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Ice build up in the freezer
Sounds like your door seals are not seating causing moisture to migrate past the seal and condense and freeze. Check to see if this is true will small strips of paper. If you place the strip in the door and pull, you should have some resistance. If you pull and it moves freely, your door seal needs to be realigned or replaced
Jan 13, 2018 | Amana ARB1905C Bottom Freezer Refrigerator
Freezer cold but refridge is warm
sounds to me your fan is not working its in the freezer unit it blows cold air to your fridge if its turning ,,, defrost the whole unit ... sometimes ice builds up in the tunnel the air flows through . bsc appliances 07779933829 uk
Feb 27, 2011 | GE GSS22JER Side by Side Refrigerator
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridge not cooling in freezer or fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
May 15, 2010 | Maytag MSD2456G Side by Side Refrigerator
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Upper freezer is working but the temperature in the fridge part is approx. 65 degrees -- not cold.
This is a malfunction of the control board. The control board is telling the refridge side that it is plenty cold - so it doesn't divert the cold air needed to keep the refridge side cool enough. Check to see the the coils in the freezer are frozen - if they are, unplug the unit and defrost with a hair dryer. Dry up the water and turn it back on - that should solve your problem.
Aug 22, 2009 | Refrigerators
Freezer is working fine but no cold air getting to the upper area
If freezer is cold then you are not getting air flow to the frig side. Check your air flow setting It is the one next to the thermostat. If in doubt ,just set both controls to the middle setting and check in an hour or so.
Jul 23, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Samsung RS2534 Side by Side Refrigerator Logo
175 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
