Question about Samsung Refrigerators
The L.E.D. Lights on the front of the Fridge door have stopped and it appears the whole Fridge/Freezer has stopped the wall socket is OK as the radio is operating in the same plug
  • 1,284 Answers
Hi, If you have voltage at the outlet and to the refrigerator, then check the fuse in the refrigerator plug. If that is also in good condition, then you have a problem with your compressor which you have to replace.
Take care
Posted on Jul 19, 2010
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Apr 16, 2014 | Refrigerators
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
My fridge compartment is warm... frezzer ok, How do I check to see if the fan is operating and how do I check the vents
A refrigerator temperature problem like yours is likely due to one of the following issues. Open the freezer door and listen for the freezer fan, you might have to close the door/light switch to activate the fan. There is a vent at the top of the back wall of freezer, as well as a vent at the top back wall of the fresh food section. Wet your finger and place it in front of either vent and feel for cold air flow. If you dont feel any air flow in the fridge and the freezer fan is running, you will likely have a defrost problem, either the heater, the bi metal t stat, or the defrost control have failed. Any of these will result in frost on freezer back wall. YOu may also have a problem with the damper door in the fridge, again, top back wall, not opening, or on the rare occasion I have seen a slice of wrapped cheese on the floor behind the fresh food crispers covering the warm air return vent to the fridge.
Oct 06, 2010 | Amana AFD2535DES French Door Refrigerator
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Kenmore Trio 596.75509400
My problem is identical to jcalhoun on Sep 21, 2008..I have a Kenmore Trio 596.75502400. Freezer is ok..Lights are on. Any help would be appreciated.
Sep 21, 2008 | Refrigerators
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
65 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
