Question about Halo UVST Bagged Upright Vacuum
Halo vacuum makes a loud noise
My Halo vacuum makes a very loud noise and the rolling brush doesn't work. I also don't think it's sucking up anything. Did my motor go out ?
D.C. 17 makes a loud whining noise when beater brushes are engaged. Normal sound until then. Replaced belt. Still so loud it hurts my ears!
Could be the brush roll, remove brush roll and see if noise is still there when brush roll motor is running.
Sep 18, 2017 | Vacuums
Shark nv350 making loud noise when switched for carpet
HI, it's Jim from Crucial Vacuum!
If your Shark NV350 vacuum is making loud noises when switched to carpet then there are a few parts of your vacuum you can check to resolve the problem.
First thing let's check your vacuums canister. The idea is to prevent clogs and anything that will obstruct your vacuum from operating properly, and running smoothly without noise. You'll want to empty your canister after every use.
Secondly, let's check out your brush roll. Is there hair wrapped around the roll itself, or any noticeable debris that would prevent the brush roll from turning? If so remove it and manually rotate the brush roll to help unearth any hidden clogs behind the roll.
While you're examining your vacuums brush roll take a look at the belt as well. If the belt isn't wrapped around the brush roll properly this could be causing the noise. The belt should have a good bit of tension on it in order for the brush roll to turn properly. Your vacuums belt should be replaced roughly every 3 months. So be sure it's on properly and has a good bit of tension.
You can purchase replacement parts for your Shark NV350 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV350&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim
Crucial Vacuum Customer Care
Mar 19, 2015 | Shark Navigator Lift-Away NV350
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Power brush makes noise on canister model
Make sure bearings spin freely. If brush roll is not cleaned frequently enough hair can damage bearings or end caps. f
Feb 12, 2014 | Riccar Vacuums
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuum Roller making a loud noise
Your roller brush is starting to fail. If you unscrew the ends, you will find a lot of hair wound around the stem. You probably have a warped plastic end the holds the bearing. This is my problem now.... I am looking for a new roller brush as I write this. I found one for $30. Good Luck.
May 11, 2007 | Hoover U5018-900 Bagged Upright Vacuum
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Halo UVST Bagged Upright Vacuum Logo
106 people viewed this question
Top Halo Vacuums Experts
JoeVacs
Are you a Halo Vacuum Expert? Answer questions, earn points and help others
