Question about Maytag Neptune MDE5500AY Electric Dryer
I just bought a Neptune and low and behold its of course a 4 prong cord and my outlet is a 3 prong. I do have a certified electrician friend to help but I do need to have the parts when he gets here. So far I do have the properly rated 3 prong replacemrnt but and at a loss with the grounding of the unit. What grounding wire/s do I need. Thx in advance thom
    Top Expert:
  • Maytag Master
  • 81,285 Answers
Any hardware store like ACE can set u up with all the stuff u need, just ask for help and tell them what u are doing, i did this for my folks and ACE helped with parts and details of the job (love ACE), u can do this without your friend, it is easy.
Posted on Jul 19, 2010
I have a 3 prong wall mount outlet for my dyer and want to put in a 4 prong. how do I do it?
Veronica,
If you are talking about the outlet you plug your dryer into, that would require an certified electrician to make the change since that is covered by electrical codes. If you are talking about changing the pigtail on the dryer, you could do that yourself. Just remember to take the brass strip off that goes from the middle of power cord block to the ground. You have to separate the neutral from the ground in a four wire situation. Hope this helps!
Mar 06, 2015 | Dryers
The outlet to plug in my dryer in is a 4 prong but the admiral super capacity dryer is only a 3 prong....i got da replacement 4 prong but when i went to replace the cord the dryer only had 3 wires that are...
2 prongs are for ground and 2 for voltage assuming you live in a mobile home where 4 prongs are required , if you do not know where they go HIRE an electrician
Oct 15, 2017 | Dryers
Bought GE Washing Machine but have 4 prong outlet
get in an electrician to fit the correct plug to suit the outlets
May 22, 2017 | GE Washing Machines
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
New house has three prong recpticle dryer cord has four prongs. Can I use a three prong cord and strap a wire to the fourth wire on back of dryer? If not got a solution?
If the new house has an existing three-wire outlet, the simplest solution is to install a 3-prong power cord on your dryer. The following link explains the differences between a 3-wire and 4-wire configuraiton:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
So...if you need to install a 3 prong power cord, it should be wired as follows:
RED (HOT) 120VAC to RED
BLACK (HOT) 120VAC to BLACK
WHITE (NEUTRAL) 0 VAC to WHITE - a Ground wire needs to be connected to the Neutral lead at the terminal block and grounded to the dryer cabinet.
The other alternative would require you to install a 4-wire receptacle so you could still use your current power cord. A certified electrician is recommended for this job and may cost you some money. A replacement power cord, on the other hand, usually costs less than $20 and can be found ay any hardware store.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 10, 2010 | Dryers
I have a wall outlet that is made for a 4 prong dryer and i have a dryer with a 3 prong, i went to the store and bought a new cord besides knowing its for a dryer do i need to know anything else, i bought...
When you put the cord on the dryer,the white wire goes to the center wire terminal. Black and red go to the 2 outside terminals right and left. The Green ground wire attaches to a ground screw outside the terminal cover.
Oct 08, 2009 | Frigidaire FEQ332E Electric Dryer
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
Dec 07, 2007 | Maytag Neptune MDE6700A Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
