Question about Microsoft Xbox 360 Elite Console
My xbox 360 shows one flashing red light with error message E74. What is E 74 and how do i fix it?
  • 864 Answers
this means the cpu/gpu has overheated. you can fix it but first read through what i have posted.
if the unit was purchased less than three years ago you can still get it covered under warranty as addressed on microsoft by clicking here. this is actually a serious problem and effects a few consoles, much like the RROD if it is not under warranty you can try doing this and i stress the not. Make sure of this by calling microsoft before attempting this. if you do not want to do the overheat fix i suggest either A. find a company that fixes xbox's and provides a real reflow. Not a heatgun and a fan. But a actual infrared reflow station. or B. Send it to microsoft and pay the money to get it repaired. or C. sell it on your local craigslist or to someone that repairs them locally and use the money to buy a new xbox 360 slim or a used xbox 360 that is working but then someone might have already done the overheat trick and it may not have much life left.
my xbox 360 shows one flashing red light with - utube.png You-Tube video "OVWmN7BTt2M" placeholder (do not delete) utube.png
http://www.youtube.com/watch?v=OVWmN7BTt2M
i have done this before and after he 2nd time i sent it to a company to reflow the xbox for 30 dollars. An i havent had a problem since. remember what is done in the video is only if your not covered under the extended warranty or e74
Posted on Aug 26, 2010
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 was saying error e74 now it will just turn on but screen is blank.pls help me
Nov 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
Switchs on comes up with e74.has 1 red light flashing on front f unit
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance
click here to download.....................
Oct 14, 2010 | Microsoft Xbox 360 Console
Three flashing red lights
3 red lights is the gpu and the cpu overheating if you stop the heat build up getting to the chips it will work for you you can do this at home or you can use a good guide to fix this error.
Jul 23, 2010 | Microsoft Xbox 360 Console
E74 error and flashing light on xbox 360
Your console has a general hardware failure, if your console is less than 3 years old, and has not been tampered with in any way, ie: the console has not been opened, microsoft will repair this FREE of charge,
visit www.xbox.com/support to book a repair.
Mar 09, 2010 | Microsoft Xbox 360 Console
3 red flashing lights on xbox360
General Hardware Failure
usually caused by the E-73 Error from defective X-Clamps/Heatsinks
Feb 07, 2010 | Microsoft Premium System for Xbox 360
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
Oct 19, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
