Question about Medion M3 Composer 5100 PC Desktop
After starting my PC I only hear a peep
After starting my old Medion Desktop PC I only hear a long peep followed by 2 sec pause and 2 sec peep and so on. Does that indicate a memory problem?
  • 86 Answers
Http://forum-en.msi.com/index.php?topic=86906.0
Check that out. I believe that you are looking for the AMI bios beep codes. You can pair up the beep type with the error that you find on that page. That should give you a little more direction.
Posted on Jul 19, 2010
    Scholar:
  • 70 Answers
If you are getting long and short beeps it is possible that the graphic card on your system is not proper.
Either the graphic card is gone bad or it is not seated properly
Try to open the computer tower, disconnect the Graphic card and then see if it still beeps. If it does not beep after removing the graphic card try to reinstall the card and see if it is beeping. If the computer beeps even after reseating the graphic card then you will have to replace the graphic card.
Video stops and starts every video
sounds like your processor is overloaded.
open your task manager and turn off the un needed processes that are running and see how that dose.
Jun 02, 2009 | Gateway GT4024 PC Desktop
Lost the 2 cd for my medion pc
Google a download of the data you need.
Jan 20, 2009 | Medion M3 Composer 5100 PC Desktop
Medion Desktop won't boot. Flickering power light????
I agree with the hard drive solution. I would check that first.
Dec 25, 2008 | Medion MD-1704 PC Desktop
Computer do not turn on
Can you hear any sound (cooler or peep), can you see any start logos? If no and your power cable is connected then your power supply needs to be changed.
Dec 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Medion PC model MD 1777 wabout 4 yrs old will not start/boot up. Blue light just flickers continusly and makes a tapping sound.
Remove any disk inserted n your computer (floppy or cd) and try again.
Check the cables connection and monitor connection.
If no boot, try boot your PC using the CD restore provided with your machine
Oct 12, 2008 | Medion MD-1704 PC Desktop
Medion pc keeps rebooting just as starting to load win xp home
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
Mar 15, 2008 | Medion MD-1704 PC Desktop
Desktop PC
Hi mos, Your board uses an AMI bios. You can see the specification here: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=46&CategoryID=-1&DetailName=Specification&MenuID=1&LanID=9
AMI BIOS beep codes
1 short = DRAM refresh failure
3 short = Base 64K RAM failure As noted at this link: http://www.computerhope.com/beep.htm
Suggest you remove your memory & re-seat one dimm at a time booting after each re-seat. If this is new memory insert old just to check board function. Shut down & try new memory. It wouldn't hurt to check against the manual pg. 6
2 DDR (184 pin, 2.5V) + 2
SDR (168 pin, 3.3V) DIMM sockets with a total capacity of 2
GB system memory
Need to test you memory? http://www.memtest.org/
Scroll down, about half way down the page to where you'll see............
** Memtest86+ V2.00 (08/02/2008) ** Typed in red. Pick you flavior.
Download - Pre-Compiled Bootable ISO (.zip) for CD OR
Download - Pre-Compiled package for Floppy (DOS - Win)
Feb 20, 2008 | EliteGroup P4VMM2 Motherboard
Computerwill not start
if you can't even access the bios, the first thing i'd do is to try and reload it. open your computer, find your motherboard, and find the little cmos switch.change it's position, wait a for 30 secs, the flip it back in the previous position. if your computer still won't start, then your motherboard is prolly faulty and you need to get a new one.
your ram can be removed by first pressing down the little switches on either side of the thingy that holds the ram, and then gently removing it. when you put in the new ram, make sure your pc is placed so that you're putting the ram in from above. then just gently squeeze it in and flip the switches back. you should hear a click.
Dec 07, 2007 | Medion MD-1704 PC Desktop
Medion M3 Composer 5100 PC Desktop Logo
412 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
